Not a happy man...
Denis Ch�nard, Orl�ans, Ont.
>Some may remember a couple months ago a post I wrote about my Ridgid job site saw having a warped top. Long story short, I brought it to the service center in Ottawa, they looked at it, and agreed to replace the top under warranty. I was told that it could take up to a month to receive the top, and that I could bring the saw back home in the meantime, which I did.
A couple weeks later, I got the call that the top was in, so I brought the saw in for the installation. Picked it up a couple days later, and everything was fine, or so it seemed.
I didn't get to use the saw until Saturday, when a friend needed a piece of cedar ripped. Since I had never been to that service center before, I had removed the Forrest blade from the saw and left the original blade installed in its holder (no saw installed on the arbor), just in case...
Boy was that a wise decision! When I saw the original blade installed on the arbor, that reminded me to put the Forrest back on. Simple enough, right? The saw uses two wrenches, an open one for the arbor shaft and a closed for the arbor nut. Started loosening, nothing, the nut has been overtightened. Pulled as hard as I could, and the arbor wrench would jump out of its slot, no way to hold it there, and no space for a standard wrench to fit in there. I had to block the blade with a piece of wood and pull on the nut wrench with basically all I could muster (which is a lot) in order to loosen the nut, blade buckling in the process. Whoever the idiot who tightened this nut deserves things I can't mention here...
But that's not all! Once the nut was off, I found out that the arbor washer wouldn't come out. I had to use pry bars to get the washer off!!! Once I got the washer off I found out that by tightening the nut the way they did, they managed to crush this domed washer to the point where it "pinched" the arbor!
Whover did this must have used a major impact driver or something equivalently powerful...
Now, to add insult to injury, I stopped by Mytek this morning on my way to work, and the guy at the counter started telling me that the problem didn't come from them, that I tried to turn the nut the wrong way, etc. I had to argue with him that there was no blade installed when I brought the saw in, that there is one now, that I had not used the saw since picking it up, and that I know how much torque should be applied to a tablesaw arbor nut. Felt quite insulted, thank you...
In any case the guy ordered a new washer, if he attempts to charge me for it I'll make him swallow the washer... Now I hope nothing else has been damaged by the stupid job they did... I'll fire an e-mail to Ridgid to see if they care...
There, feel a bit better, sorry for the long-winded rant,
DC
