Re: Alaskan saw mill recommendations?
Robin Corell in Atascadero, CA
>Milling is the most abusive and demanding use of a chain saw. For that reason it is always a good idea to have more saw than you need. Pay attention to the maximum length of bar recomended for a particular saw and then mentaly add 6". You will need an extra 6" of bar and chain to be able to clamp the bar in a mill and still be able to get the length of cut a saw is recomeded to be capable of. For instance my 038 Magnum is a 72cc saw with a maximum recomended bar length of 26", I have a 32" bar and can take a full 26" cut when it is set up for milling.
This brings up the question of what size mill to go with a particular size bar. You will lose about 6" of bar length by the time it is clamped in the mill. My other saw has a 42" bar and by the time it is clamped in the mill I can only make a 36" cut. The simple math would indicate that a mill 6" shorter than your bar would be the appropriate size. I actually prefer a mill 6" longer than my bar and have a 48" mill. the rails extend past the tip of the bar to provide a bit of protection when it is in the back of my truck and the extra length only adds a few ounces to the weight and pennies to the cost. Also if you are contemplating a 22" or 36" bar, having a longer mill will allow you to move to a bigger saw.
Now as for particular saws I prefer the older Stihl's. The alltime best miling saw is generally agreed to be an 090. At 137cc it is a brute and at 30 lbs it lets you know it. even used these saws average about $1000 and almost always look like they were rode hard and put up wet. Often over looked are the Stihl 075 and 051, particularly the 051. The 075 is 111cc and the 051 is 89cc, but they both have the same case, crank and carb. actually the only thing different is the piston and cylinder. Parts for these saw can be dificult to find locally but they are still available. In fact the 075 and the 051 are still available new in Mexico along with the )&) which is tha same saw as an 090 but with a smaller piston and cylinder.
As for new saws anything over 100cc will work and will most likely cost around $1000. to put this in perspective I currently have access to a bunch of claro walnut logs. I can mill about 200-250 BF of 8/4 in a day. currently claro walnut is between $10-$15/bf dry and $4/bf green is considered a good deal. Do the math and you can see how one day of milling high value wood can pay for the equipment. Of course finding high value wood is the real trick.
Robin Corell
