Help me think this out here!!!
Rob Hix - King George, VA
>Hey all,
I am building some bookshelves and I the plywood I am using has a little warp to it. Specifically it appears to start about 2 feet from one end and it warps up about 1/4" over that 2 feet.
I am putting a shelf (the bottom) right at the bottom of the side, it will be glued and screwed into a rabbet. I am also putting a fixed shelf at about 27" up the sides. At the top I am using a 2" wide nailer across the front of the shelf and and a 2-1/2" wide nailer across the back of the unit.
Where would you locate the worst of this bending? It is not bad enogh that it will not straighten out. Just wondering where you would put it?
Thanks for your input,
Rob Hix
