Where Hardwood Lumber comes from 7-sawing the log
Bill Tindal, E.TN
>Part 7 The Head Saw
The first saw (the �head saw�) a log encounters in a typical hardwood mill is a circular saw. The job of this saw is to make at least two parallel flat sides on the log and in most cases this saw also removes as many high grade boards as the log will yield. In smaller mills this is the only saw that makes boards from the log. In larger mills this saw saws the log down to a cant- a portion of the log with at least two parallel faces- and the cant is sent to a band saw or a gang saw (more on this operation later) that more rapidly converts the cant to boards, usually lower grade boards. The circle saws are fast and accurate and most importantly, it will be the only saw in the mill where the log can be turned to search for the clearest log faces to produce the highest grade of board. The clearest lumber will be found on the outermost part of the log.
Sawing strategy Our retail customers often would be astonished that we didn�t have �6� boards� or other even width of their choosing. In a softwood mill the objective is to make boards of a specified width. In a hardwood mill the objective is to get the highest value boards from the log, with little regard for width. Clear boards from the outside of the log can bring ten times what the pallet lumber from the heart brings. First a slab is removed from one face of the log. Then the log is rotated 90 degrees so this flat face sits securely on the carriage. Another slab is removed, which on a high grade log will reveal a clear face. One or more boards will be removed from this face. The log will be turned 90 degrees two more times to remove a slab and perhaps a board or two from each remaining face. At this point most, if not all, of the bark is removed and the log (now called a �cant�) is rectangular in cross section (�squared up�). With a clear log face facing the saw, the sawyer will begin removing clear boards until a defect is encountered. Then the log will be turned to the next clear face and the process repeated. Eventually all the clear lumber will be sawed from the clear cant faces and the remainder of the cant will be converted to lower grade boards. Log scanners coupled to sophisticated computer algorithms are replacing the judgment of the sawyer in some mills.
This strategy is sometimes called �boxing the heart� for the last of the log to be sawed will contain the heart(or pith) of the tree which is always low grade lumber. It is frequently sold to make pallets. (note: this is a simplified description of sawing but it accurately conveys the overall objective of the sawyer.) It should now be apparent that hardwood lumber comes in an infinite variety of widths)
This strategy involves frequent turning of the log on the carriage and it will result in boards more narrow than if the log was just sawed through in one position on the carriage. Through sawing would yield wider lumber that could be book matched. While through sawing might be more desirable for our needs it would overall yield less high grade lumber from the log. But. commercial mills saw lumber to meet the needs of furniture factories, not us. More on this important point later.
This saw typically cuts a �� kerf. The teeth, called �bits�, are removable/replaceable and held in the saw plate with �rings�. The sawyer sharpens these bits on the saw with a file, and then swages the end of the bit to widen it to provide �set� for the saw. If a nail is hit and it ruins a tooth (bit), or a few teeth, new ones can be quickly installed. If a fence insulator is hit, or a bolt, and the saw plate is damaged it must be taken to a saw shop to have it re-hammered back into shape.
The first boards removed from the log will have rough edges where the bark was attached. There are various strategies for removing this rough edge. This mill has two small horizontal saws perfectly aligned with the main saw to cut a strip from the top and bottom of a board as it passes the main saw. A laser beam shows the sawyer where these saws will cut and he moves these saws up and down to just remove the rough edge from the board being made by the head saw.
An alternative device to do this task is an �edger�. It is a sturdy �rip saw� with two vertical blades that can be adjusted to rip a board of specified width by removing a strip from one or both side of the board. Rollers grab the board and feed it in a straight line through the edger. Sophisticated edgers have lasers, scanners and computers to calculate the best value and rip the board accordingly.
Various other parts of the mill can be seen in this picture. Sawdust falls out the metal shoots under the saws into the saw pit where it is scooped up and carried away with the �dust chain� to a storage area. It will be sold for mulch or cattle bedding. You can see the small oak log secured on the carriage and behind it logs on the skid way. The sawyer has a bird�s eye view of the saws from inside the yellow booth. The window protects him from flying debris.
The advantage of the head saw and carriage is that the sawyer can turn the log to find the clearest faces to saw boards from. This process is relatively slow, but it pays off in yield from the log so long as the log has clear faces to saw from. In high volume mills once the high grade boards are removed by the head saw the cant will be passed to a faster sawing operation to saw the lower grade lumber. A gang saw is a common machine for converting cants to boards. A gang saw is like an edger but with multiple blades spaced a board width apart. It converts the cant into boards in one pass through the machine. I have a picture of a gang saw but the saws are under guards and can�t be seen so I decided not to show it.
In the next installment we will cover inspection and grading.
Re: Where Hardwood Lumber comes from 7-sawing the log
Re: Question, Bill...
Al Stokka - Cambridge, Iowa
>One the large blade to the left of the picture, on the left side (leading edge) of the blade is a device very close to the blade. What might that be? A blade stabilizer, perhaps?
Al
you are correct
Bill Tindal, E.TN
>A blade stabilizer
Re: Thanks, Bill. Am enjoying the series.
Me Too !!
Don O.
>Bill, you mentioned that the best lumber comes from the outside of the log. I assume that is because this is the part that grew after the tree had limbed itself up and that is why trees grown in the forrest are batter than trees grown in the open. (This was a little light bulb idea for me, never thought it through before.) My question is, doesn't that tend to make most of the lumber plain sawed? Cutting all the good stuff off each side as you rotate the log would seem to generate almost all plain sawed lumber.
Thanks for posting this. It's great. I had soem walnut sawn a couple of years ago on a band mill. I just took it to the sawer reccommended by a friend and let him work his magic. Now I wonder if I should have stayed and watched. Of course, I would have been about as helpful watching brain surgery.
answers
Bill Tindal, E.TN
>because this is the part that grew after the tree had limbed itself up Yes
doesn't that tend to make most of the lumber plain sawed? Again yes, however when the gang saw slices up cants there will be quarter sawed boards generated, usually of low quality.
Now I wonder if I should have stayed and watched. Indeed yes Of course, I would have been about as helpful watching brain surgery. But it would have been just as interesting.
Re: answers
Paul Leuba
>Bill, I am very much enjoying and benefiting from your series of articles. Thank you for sharing your knowledge on the harvesting and sawing of hardwoods.
I do have a question.
Does a sawyer ever consider sawing logs to maximize yield for a specific type of cut, such as: quartersawn, riffsawn or plainsawn?
Thanks again,
Paul from Hunt Valley, MD
I suppose somewhere
Bill Tindal, E.TN
