To glue or not to glue...
Barry Daniel-Camden, NC
>Biscuits that is. I seem to remember reading in one of the magazines that gluing biscuits on a large panel is unnessary. So I am giving it a shot on a Coffee table. I cut the slots for the biscuits installed them and used them for alignment purposes. Have any of you folks out there tried this or heard of this approach. Thanks.
Barry
Re: To glue or not to glue...
albertabob
>Yes, Use the biscuits for alignement only.
If you use water base glue on the biscuits themselves you run the risk of swelling or contraction of the wood surrounding the biscuit.
This often show up after the finish it applied.
Bob
Keith Newton
>If you prepared the face of the surfaces properly, then the glue-line is stronger than the undisturbed wood around it, so gluing the plates in is not necessary.
However if you do a bad job of preparing the jointed surfaces, the biscuits may be all that holds it together.
Whenever I glue up a panel, it is normally longer than the finish length. I make a practice of breaking the waste pieces after cutting to length as measure of "quality control". If it breaks on the glue-line, it is time to pull out the magnification tools.
David Yoho
>Barry, I don't glue biscuits anymore when using them for alignment. As long as your edges are straight and true, there's no need.
David
I've seen that happen....
John in New Mexico
>When a table top was sanded flat (with a timesaver) the same day as the glue up. In theory, if the wood around the biskits equilibrates before sanding the top, it should be ok.
Personally, I don't use 'em at all, using cauls and care to align the boards.
John
