Hollow Core Door question
>I bought a hollow core door at Lowes and want to cut it down from 24" to 18" to fit a small opening. Does anyone know if they use any metal fasteners in the construction. Many years ago they used corrugated fasteners, (wiggly nails) but I don't think they do anymore. (I don't have a metal detector, so don't even suggest that, thank you very much.)TIA
Re: Hollow Core Door question
Al Stokka - Cambridge, Iowa
>Barry,
No metal in hollow core doors in my experience. BUT, I' d be absolutely amazed if you can remove 6" in the width of such a door without exposing the guts (corrugated paper). At the very least, you'll expose finger-jointed stiles which will look like heck if you don't veneer the cut edge.
Al
>Al, you are right. The stile is about an inch wide. My plan is to rip the door to eighteen inches, surely exposing the guts. If anything is in the way, I will rabbet the edge, and either make a new stile or rip the existing stile out of the "drop" and reinstall it. Not as much work as it sounds like. I have a table saw and will make short work of this. I was just wondering if I should take my Forrest WWII blade off it and put on one I hate. I can order a 18" door but it take two or three weeks to get one and it costs more than a 24" one I already have. I'm working on a rental house and am ready to move this along, not wait on a special order door. Thanks for your help.
PS, I need something to cover the "toe kick" under the kitchen cabinets. I may remove the remaining five inches of the door skins and stain it and install it under the cabinets. What do you think? Is that frugal? Green maybe? Nothing going to the landfill.
Joseph Mulherin
>Barry, take the 6" out of the center and leave the edges alone. then put a stile up the center to cover the cut.
>Barry In my experience they all have cardboard in the middle. You'll get some tearout so cut a score line on each side. I then take a 1" chisel and just sort of cut and push the cardboard out of the way. Then I install a new rail. It's pretty easy and fast. I make shelves this way because I have a source for cheap hollow core doors.
Re: I admire frugal, but...
Glenn Madsen near San Francisco
>for $15, I can buy any door I want from the oops pile at the door shop. Or 3 for $30. Get one close to the right size, and you'll be a lot happier, IMO.
Jim Dillon
>Barry,
Your question brought a smile to my face. Nearly 30 years ago I bought my first (and only) home and had new carpets installed. Unfortunately, all the hollow-core doors then required a good shove to close. So, I bought my first power tool - a very heavy Milwaukee circular saw. With brand new blade, I proceeded to cut off the bottom inch or so of the door. All of a sudden, about an inch into the cut, there was a very loud noise, and lots of sparks. Didn't stop me though! Kept on going until the other side when the same thing happened. When I was done, closer examination revealed huge corrugated fasteners holding the stile to the bottom rail. Even for me, it was a lesson learned. I "solved" the problem by not closing the remaining doors unless I had to. So, watch out for that area of the door; it sounds like you will be fine with your plan.
P.S. The Milwaukee saw (as well as a equal vintage 3/8 inch Milwaukee electric drill) are still going strong (unlike me 8-)), despite constant use, although the drill did have to have a new power cord recently.
Jim
DB
>If the stile is 1" wide and you are removing 6" then you should not hit the fasteners. To be on the safe side I would still change the blade.
Thanks guys......
>A door shops with an Oops pile? I would have shelves everywhere. This door wasn't but $18 "new". What happened is I put back one door in a prehung jamb. It was this flat hollow core door. I am hanging new doors in he other openings and decided to make them the hardboard molded raised panel doors. They don't have a 18" door in stock. So rather than order one, I will cut this one down and use it as a closet door and then substitute a new raised panel one on the bathroom.
And, I hit a corrugated fastener somewhere back in prehistoric times also, probably 35 or 40 years ago. The sparks and horror of ruining a blade are burned into my brain, even if I can't remember exactly where and when. I guess that was the "lesson" and it got learned.
Put a rail up the center? Interesting, but wouldn't that weaken the door?
I think I will change the blade on the TS. Now that we have discussed this, the gremlins are alert and on notice.
Re: Omigosh!
>Barry,
For sure I would not use a $100 blade for the task! Even if no metal is encountered some types of glue are abraxive enough to dull a blade. Why take a chance?
I see no reaso not to use the cutoff to cover the toekick.
Frugal? Yes, but that's not a bad thing.
Green? Who cares? The wood (and cardboard, for that matter) came from the earth and they'll eventually return there.
Al
Wayne
>I have done many doors, that is cutting them down. Just cut it down to the width you want and take the cut off and run it through your table saw to remove the hardboard or what ever it is covered with and cut the honey comb off the sides of the door you keep with a knife and install the spacer from the door and apply glue and clamps and blocks to each side to distribute the pressure and wait until tomorrow then clean it up and you are ready to complete it. You might think of installing another block where the lock goes or the door will squeese together at that point when you tighten the knob.
