large dowel nuts
Patrick Capobianco
>I'm looking for large dowel nuts for for my 6" x 1/2" bolts to attach aprons to legs for workbench. Does anyone know of a source?
large dowel nuts
Patrick Capobianco
Re: large dowel nuts
>I will be interested in this answer also.
I made some recently for a bed I made for my son. Mine were 3/8 bolts and I used a 3/4 steel rod from the borg and drilled and threaded the holes myself. I cut them two inches long. Worked great, made a very solid joint.
I would think you would need the dowel to be about 1". If you drill a 1/2" hole through a 3/4 dowel there woudl not be much strength left. 7/8 might work. Could you use 3/8 or 1/2" by about 1" flat stock and mortice the holes?
