Re: Wood puzzles there is an expert
Falberg saw Co
>Once again the conventional wisdom is completely off track in regards to two wheel/three wheel design comparison. Industrial applications favor the multiple-wheeled approach because it's basically more efficient. Industrial three and four wheelers generally use better components: bearings, wheels, frames, etc. throughout and they are far superior to any two-wheeled consumer bandsaw in terms of power requirements and blade life. The biggest difference between two and three wheel designs is cost. Three wheelers require bigger and stronger frames, more efficient wheels and bearings, more sophisticated tensioning systems, and more complex alignments.
Three wheelers of the consumer/hobby variety have generally been made to compete throat-wise with the cheaper two-wheel models and historically they do this by using the cheapest parts obtainable; such as *plastic* wheels and even *plastic* wheel bearings, if you can believe that. Nonetheless, you CAN get a lot of good use from even a dirt-cheap three-wheeler if you correctly understand the basics of cutting with a thin strip of steel.
The ancients used treadle-powered strands of diamond-saturated silk to cut jade which was extremely crude compared to the slick sophistication of my first plastic-bearinged three wheeled cheapo bandsaw. In either case, it's the blade, not the machine, that makes the cut. The machine is only there to move the blade. What makes a machine efficient is the elimination of vibration, friction, and heat build-up on the moving parts; regardless how many wheels are used.
If cost is your main consideration, get the cheapest used bandsaw you can find. They're all the same.
While there are virtually no differences in quality between the umpteen brands of two-wheeled bandsaws, there is a world of difference between the brands of blade you can put into those machines. ALL of them are good; for something. FEW of them will cut more than 4" deep without drifting. Unfortunately, two-wheeled consumer bandsaws are so inefficient, machine-wise, that their throats are constricted to an average 10" cut depth and you need a 1HP motor to even start those big cast iron wheels turning. There just isn't enough reserve power to cut big workpieces so the blade manufacturers don't bother supplying blades for deeper cuts. There's no market; and thin kerf blades are so much more profitable to make and sell. *FLAT* cuts are not even mentioned in their ads.
Cheapo saw + quality (set) blade > Expensive saw + cheapo (unset)blade. ;<)
