All-In-One Clamp Guide? *LINK*
>Anyone have one of these from Rockler and is it worth the price?
I have my 25% off postcard from Rockler (no power tools). I was looking to spend it on something which made cross cutting plywood easier. Of course if they made it 100" long, there would be no question :).
All-In-One Glamp Guide
Re: All-In-One Clamp Guide? *LINK*
Dave's Not Here
>I got one from Rockler when they had it on sale for about the same price as you'll pay with the discount. I haven't used it a whole lot but the times that I have it's worked alright. I didn't notice any flex at all with it. When I first received it I couldn't get it to lock down properly. A quick call to Rockler fixed that though. Seems the factory sends them out with one end not fully assembled for some reason. A simple snapping together of the end piece solved the problem.
Ells in Boulder
>Not Rocklers' model but I have what is maybe the original, Tru-Grip Clamp-an-Tool Guide, 50" and 24" versions. Very handy and yes, excellent on the sheet products with a circular saw. Shorter one good on smaller pieces and doubles as a drill press/bandsaw fence. Once saw a post somewhere complaining of a little give/looseness in the 50" but I've never noticed a problem.
Ells
Tru-Grip 24 and 52
>Hi JL, I have the original ones that I got at WoodCraft about 6 years ago. The Tru-Grip CT24C and CT52C and they are absolutely worth their price (about $0.80/inch and $1.00/inch).
I think I'd be frustated having only one size. They are both so handy and are excellent at what they do.
I used them last weekend cutting 1/4" of the bottom of some doors in the house. They are one of those tools, that once you get them and use them, you quickly forget what you paid for them and wonder how you lived without them.
Happy Woodworking!
Bartee (metro Atlanta)
>I have several including these double sided ones that I use on my work bench.
I also have a 50" that I use all the time for a sawguide when cutting sheet goods.
The do what they do very well.
Andy Lincoln,In Dearborn MI
>JL,
Here's an expanded use of the clamp-n-tool guide.I built it into a crosscut jig.
The idea is an improvement upon using a circular saw as a method to crosscut sheet goods into smaller manageable sizes. For years many people have used a simple guide of plywood to ride the saw against and cut sheet goods. My improvement is the addition of a clamping tool guide to the underside of the crosscut guide .By attaching to the underside the hassles of the clamps interfering with the saw motor is avoided, potential mistakes are avoided by not having to measure/allow for an offset between the tool and the guide, clamping is achieved from one side of the sheet, not reaching over and/or moving to the other side of the sheet.
I sized this guide to 56", which is the length of the Clamp-N-Tool guide(tm), which allows for a clamping capacity of 50". The process and materials could be sized for other clamps (24" and 36") as well as for different manufactures of clamps. I believe Rockler and Woodcraft both sell a similar style of clamp.
I constructed the guide from birch plywood and used polycarbonate (left over from another project) as a base for the guide. The edge that the saw base rides against is covered with plastic laminate. The guide is attached via screws countersunk from the guide into the birch plywood. The polycarbonate is screwed in place and could easily be changed if damaged. This guide could also be used with a router instead of a circular saw.
Jim Dillon
>JL,
If you can get a good price on them, go for it. I have several of the Tru-Grips and they are indeed useful. And the jig built by Andy would be VERY useful IMO. I've never noticed any flex, but I suppose if you pressed hard enough... .
Jim
Pretty neat!
Denis Ch�nard, Orl�ans, Ont.
>I might just have to make me one of those...
Thanks for the pics/description!
DC
Re: Thanks for the recommendations...
>I'll buy one tomorrow. Now if I could only think of what to use the other coupon for...
