Mouse pad reacting with finish
Forrest Smith
>Recently finished an office desk for the wife by spraying and rubbing out lacquer and polishing with wax. Looked fine but after a few days noticed that the rubber backing on the mouse pad and the plastic feet on the monitor were reacting with the finish causing indentations. I had seen this on furniture we had bought so I should of know better. Thought polyurethane would offer more protection but after stripping the top and refinishing we see signs of the same thing happening. Is there a finish that would be better in preventing this? Thanks. Forrest
Re: Mouse pad reacting with finish
Robin Corell in Atascadero, CA
>I can't offer a soulution but I can add that I had a similar problem with an acrylic finish I used on a concrete counter top I made for my brother and the rubber feet on a knife block and a waffle iron. The appliances with hard plastic feet did not leave marks so we switched to using those. Not sure this would be a soulution for a mouse pad but I thought I would mention it because acrylic can be prone to the same problems you are having.
I would consider doing a test with a modified tung oil finish.
Robin Corell
Re: Mouse pad ...Tung Oil + Wax
Kneale Brownson in Northern MI
>A lot of modern finishes need to "cure" for days or even weeks before they reach their maximum hardness.
When I want to put something to use quicker where stuff will sit in the same spot all the time, I usually do a tung oil finish of at least three coats and then wax. Don't know why I do the wax, but it's just become one of my standard approaches.
Sawdust Everywhere!
>It's the solvent in the finish! Unless you're using water based finish, the oil based solvent will react and dissolve the rubber mouse pad material.
Oil based finishes are also bad for acrylic as with alcohol based finishes. Alcohol maked arcrylic brittle and crack.
Try WB finish next time or let the finish dry out for a really long time before using.
Forrest Smith
>Robin, interesting that you would mention tung oil. I had recently helped my brother-in-law with a desk/table over Christmas and he had used tung oil but without the wax. Strangely he recently mentioned that his mouse pad had left marks on that finish as well. Thanks. Forrest
Bob McGovern
>No, it's *not* the solvent in the finish. What you are describing is a well-know phenomenon known as 'printing,' and it is 100% the fault of the mouse pad. Foam rubber (open or closed cell) uses powerful solvents like xylene, toluene, and hexane during manufacture -- it's what makes it swell up and creates those lovely little bubbles. Some of the solvent remains in those air cells for quite a long time and only slowly outgasses. Since xylene and toluene are also called 'lacquer thinner,' you can see why slow persistent contact with any finish -- even fully cured polyurethane -- will lead to printing. The foam rubber 'burns' into the coating. It's the foam's fault, not the finish's.
I tell my clients to replace all their synthetic foam lamp bases and so on with felt or cork. End of printing. Use a non-foam or fabric-backed mouse pad, you won't have a problem. (You ever seen a foam rubber shelf liner melt into a latex-painted cabinet shelf? THAT'S six kinds of ugly, right there!)
Forrest Smith
>Thanks to all. Forrest
