Hardi board cement siding?
Ernie Miller
>Has any one used this stuff? it appears to be pre primed do I need to put another prime ove that to get a good paint job that will last? Any tips or tricks to getting a good paint job?
Ernie Miller
Re: Hardi board cement siding?
Bill McDonald
>have not used it but want to build a cabin in Prescott and use it for siding. Has great fire resistance.
Bill White
>I am using it on house #2. I primed the first house, but on the new one I am using the SW exterior paint that requires no primer. I had to "push" the insurance company to qualify it as a masonry bldg. they finally relented.
You will not be unhappy. Only down side is that the stuff does NOT like golf balls.
Bill
Rob Stokes in North Vancouver
>I used it on my shop and fell in love with the stuff. It's a pain to work with though. Do yourself a favor and rent a guillotine to cut it with and a proper (pneumatic) nail gun to mail it with. It can be cut with a circ. saw, but it's really messy and it can be hand nailed, but that results in very sore fingers (you have to hi the nail hard to puncture the concrete and if you don;t hit it hard enough, the nail bends onto your fingers - ouch!).
Also will want to think through the whole hanging process. Long pieces are heavy and wobbly - this is NOT a one person job.
BUT - when it's up, it's going to last forever and it takes paint and caulk extremely nicely.
Hardi-plank is definitely in my short list next time I'm contemplating a siding job and it earned the right to be there.
Rob
Ernie Miller
>It's all up and I nailed it by hand but no bad fingers. but Megan on the other hand has some sore fingers. I was just wondering about the primer thing? Guess I will prime it and be done with the process. I have about 14 more windows to calk and a couple seams. I used the 4X9' boards and they are heavy. I'm thinking the rest of the house will get it soon I hear they make it with pigment in it so it never needs painted and I would like that but haven't seen it localy. so the sun room will get painted to match the house.
Clay Foster
>I used Hardi planks on my shop. I took Hardi's word that it was primed, so I just painted it. That's only been a couple of years ago, but no signs of any problems.
I used a carbide blade in a circular saw for cutting it. I cut outdoors with a bow fan set up to blow the dust away from me.
I bought a Hitachi NV 75AG coil nailer for nailing it. It also was great for nailing the sheathing and roof decking.
Just two coats of latex.
Ray Thompson - Middletown,IN
>Let the first one be the primer, it is pre-primed from the factory. Mine has been up for 6 years now and shows no sign of paint problems. My painter used Sherwin-Williams, the high end stuff, don't know the name.
Ray
Pete LaBelle
>We used the stuff on a couple buildings in Biloxi that we were rebilding after Katrina. Seems the instructions had a specific primer to use. Check them out. Instructions are normally right.
Hopefully...
Jason Roehl in Mulberry, IN
>...they used Duration. Super Paint isn't bad, either, but it doesn't hold a candle to Duration.
Oh, and they're both 100% acrylic...latex is becoming pretty much extinct, but can still be found in cheap paints.
Jason
>I replaced the siding on three dormers in my old house with the Hardiplank siding. I primed it anyway with tinted primer. That way I didn't have to use too much of the expensive paint.
VLParisian
>Helped my son put up new Hardy Plank facia boards on his house. We had trouble nailing it at first, bending every other nail and then some. We finally settled into holding each board up in place while his wife marked all the rafter ends. Then set the board down on the ground and predrilled each board one at a time. Nailing went way quicker then.
On the long boards do not attempt to carry them by yourself over head like a normal board. They snap real easy. No, I didn't learn this the hard way. Several years ago I watched a guy in the parking lot at Home Depot trying this as he was loading his car. oops.
Regards,
Victor
Re: "Semi"Hardi board cement siding?
Wayne
>IT ALSO DOESN'T LIKE GRANDKIDS WITH HARDBALLS AND BATS EITHER. It doesn't like golf balls shot from under riding mowers either. But seriously if you use it be careful with the nails if put to close to the edges it will brake them. The stuff is real good and won't rot and the termites don't like it either.
