200+ woodworking book reviews
OT--fixing the wife's hard drive
Gary Evans Tallassee, TN
>Hi all,
I'm trying to replace the hard drive that crashed on Beth's computer. I can't load XP from my disc because it is an upgrade version and the new drive does not have Windows on it.
I have an old hard drive that has a legal version of Windows. If I could copy it onto the new drive I could proceed in a timely fashion.
The folks that built her computer never gave her a disc with XP on it. Consequently, I don't feel bad about using another version as the basis for the upgrade.
Any help would be appreciated.
Thanks,
Gary
Re: OT--fixing the wife's hard drive
Ghosting software may help
Eddie Pacheco, San Jose, Ca.
>Gary, you can purchase ghosting software and make a direct image of your XP drive or the other Windows drive. "Norton Ghost" is $70 and can be downloaded. They also have a free "trial" version, but I have no experience with how the freebe version works. Norton Ghost does work real well though and I've used it several times.
There is also "Casper 4.0" for about $50 which also can be downloaded.
There may be some other freeware out there for this, but it could have problems and leave you with no OS.
Good luck.
Why can't you use the old windows drive in the new PC?
http://www.symantec.com/home_homeoffice/products/overview.jsp?pcid=br&pvid=ghost10
http://www.fssdev.com/
Chuck W
>Gary,
There is a free utility from Seagate called Maxblast that will allow you to make an exact copy of the old drive to the new drive.
Don't bother
>Don't bother with Ghosting, it's not necessary.
There are a couple of easier things youc can do.
1 - Get an old Windows CD. All you need is an old Windows2000 or Windows98 CD. Email me with your address and you might find one in your mailbox.
2 - Depending on your CD, it might be usable with a new activation code. Call Microsoft. You'll speak to a real person in about 1 minute and have what you need in about 5 minutes. I think the number is: 800-936-4900 but I'll have to double check that.
Happy Woodworking!
>Thanks guys,
I'll try calling Microsoft and see what they say. If they can't help me, I may be in touch with you, Mark, to get a disc. The only reason I don't have a disc with some complete version of Windows on it is that my last two computers have been used ones. When I bought the upgrade to XP, I was going to get the full monte, but my local guru told me that the upgrade had everthing on it that the full one does. I guess he didn't realize that the upgrade would be looking for an orginal version before it would proceed.
I tried running the upgrade's repair console on her old drive, but couldn't get it to go very far before I got a blue screen message.
The hard drive that I have with 98 on it is tiny, only about a gigabyte so I don't want to use it as a primary. Part of the reason for choosing the new drive that I did is that I'm hoping having some cache on the drive will help to speed her machine up a little. Her computer is supposed to have a chip half again as fast as mine, but things happen on that one at about half the rapidity of mine.
Plus, (don't tell her I said this!) I need to keep the operation as simple as possible. I don't think my wife would cope well with having to move back and forth between drives to hunt for stuff. She's not very computerate, and if she has trouble it will be my fault.
Gary
Jerry Nicholson
>You should be able to copy your little Win 98 drive to a big drive without buying anything. You will need a Win 98 boot disk (I assume you have a floppy disk drive). Format the big drive with Fat32 first. Use XCOPY with appropriate parameters so everything including hidden files is copied. I haven't done this for a few years so I can't give you the correct incantations off the top of my head. You might have to go back to FDISK and make the big drive ACTIVE after you are through with copying. Assuming you can then boot from the bigger drive and Win 98 is working OK, you can then upgrade to Win XP. Or like Mark says, have a Windows 98 disk standing by for when the XP install complains that it can't find a legitimate operating system to upgrade. I have done it that way several times since when I upgrade to XP I don't want to carry all the old Win 98 baggage along.
Jerry
Bill Howatt
>For using XCOPY the switches are /H/E/C/K
Here are the details on the command including all the possible switches:
For transferring all files including W98 OS. System will boot if MBR present and partition active.
Start Run
C:\windows\command\xcopy32.exe C:\*.* D:\ /H/C/E/K (space between D:\ and first switch, no spaces between switches. Space between * and D.
C is source drive, D(or whatever) is the destination drive.
XCOPY source [destination] [/A | /M] [/D[:date]] [/P] [/S [/E]] [/W]
[/C] [/I] [/Q] [/F] [/L] [/H] [/R] [/T] [/U]
[/K] [/N]
source Specifies the file(s) to copy.
destination Specifies the location and/or name of new files.
/A Copies files with the archive attribute set,
doesn't change the attribute.
/M Copies files with the archive attribute set,
turns off the archive attribute.
/D:date Copies files changed on or after the specified date.
If no date is given, copies only those files whose
source time is newer than the destination time.
/P Prompts you before creating each destination file.
/S Copies directories and subdirectories except empty ones.
***** /E Copies directories and subdirectories, including empty ones.
Same as /S /E. May be used to modify /T.
/W Prompts you to press a key before copying.
***** /C Continues copying even if errors occur.
/I If destination does not exist and copying more than one file,
assumes that destination must be a directory.
/Q Does not display file names while copying.
/F Displays full source and destination file names while copying.
/L Displays files that would be copied.
***** /H Copies hidden and system files also.
/R Overwrites read-only files.
/T Creates directory structure, but does not copy files. Does not
include empty directories or subdirectories. /T /E includes
empty directories and subdirectories.
/U Updates the files that already exist in destination.
***** /K Copies attributes. Normal Xcopy will reset read-only attributes.
/Y Overwrites existing files without prompting.
/-Y Prompts you before overwriting existing files.
/N Copy using the generated short names.
>Thanks, Bill,
That's exactly what I needed. If that doesn't work, I'll see if I can get someone to send me a copy of Windows.
Gary
