Re: OT: Welding - long reply
Larry Clinton At Frankfort (Central)., Indiana
>Asking what do I need to weld is kind of like asking what saw do I need to cut some boards to make furniture, decks - cabinets etc. You will get about as many answers to your welding question.
First a basic primer on the types of welders available and their typical uses.
1)Arc welder: These can be a simple AC (alternating current) "buzz box" or a AC/DC (AC + selectable direct current) , or an AC variable frequency welders (some may also have DC capability). All of these welders are also called �stick welders� as they use a stick (welding rod with a flux coating). The �buzz box� is the cheapest welder available � it is also the hardest to learn to weld with IMHO. Normally these type welders are typical used to weld 1/8� to � � mild steel / iron (180 amp versions). Arc welders normally require 220 volt input and are available with outputs from 120 to 300 Amp. (I have a 295 Amp buzz-box). Slightly thinner steel can be welded with some training � down to about 1/16�. With higher amperage units thicker metal can be welded. With the variable frequency control, very thin materials can be welded and the arc is very easy to strike and maintain. The DC capable units have better control of the weld penetration, can weld thicker material (IMHO) better and it is easier to strike and maintain an arc with the DC.
2)MIG welders: These are Metal Inert Gas welders. These use a wire which is automatically fed from the end of the electrode, the wire takes the place of the �welding rod�. These originally were equipped with a tank of compressed gas � usually Argon or Argon / CO2 mixture. This gas is automatically fed through the electrode, bathing the welding area in an inert gas � this prevents oxidation of the welded material. There is also a cheaper version which used �Flux core wire� � The flux core emits a gas during the welding which also prevents oxidation. The Flux core is only available for mild steels. The Gas fed version of these welders are capable of welding steel, Stainless steel, aluminum etc., when used with the proper shielding gas and wire. Most MIGS are more expensive than the comparable Arc welders. Typical uses of these welders are thin material 1/32� to max. �� � with the normal units sold for home use. These are very easy to learn and use. These are available as 120 Volt and 220 Volt input units. Amperage varies from 85 to 250 Amp. (I have a 115 Amp MIG).
3)TIG welders: These are Tungsten Inert Gas welders. These have an electrode with a replaceable tungsten point; the arc is struck between the tungsten electrode and the work-piece. Inert gas is automatically fed around the arc during the welding process. The welding material (bare wire type rod) is fed into the arc with your other hand, somewhat like soldering. These are capable of welding very thin to thick material and will weld Aluminum, steel and other materials. These are fairly easy to learn and very versatile � also a good unit is quite expensive. I have welded with a TIG a couple of times, but do not own one.
4)One thing I would recommend is a decent �auto-darkening� helmet. These have a (almost) clear lens that allows you to see the welding area until the arc is struck. Then they immediately darken to prevent eye damage. These cost $50 for a cheap one to 2 or 3 hundred for the best. They can be used with all types of welders.
My suggestion to you is that you continue to learn the welding process. After you have became proficient in welding with the arc / stick welder, you can decide if you need any other type. A decent buzz box can be purchased for a couple hundred or so. A MIG will run $300 and up + gas tank. In my opinion I don�t see you justifying a TIG � A decent unit will run a couple thousand or more + tank.
