Re: Exterior finishes?
Steve Schoene
>I doubt epoxy would be good on wood that lives in the sun, though I don't know that particular product. Epoxy has no natural UV resistance and UV absorber's can't be added I don't believe.
There are NO clear finishes at the Big Boxes or Ace Hardware (unless you are in one of a few yachting mad towns) that are acceptable for wood in sunshine.
Oil finishes can work, but to keep the wood from turning grey, it will need to be cleaned and a maintenance coat added several times each year. (Monthly in full sun below New England latitudes)
For film finishes you only want good marine spar varnish. There are three brands of good marine spar. Epifanes Clear High Gloss, Interlux Schooner, and Pettit Captain's. Follow the instructions, including the requirement of using 6-8 coats. They are only available boating supply stores. Jamestown Distributors mentioned above is good, and www.defender.com offers quite good prices. Even with these products an annual (or bi-annual if there is quite a bit of shade)scuff sanding and an additional coat of finish is necessary.
I suppose there are two part finishes such as Interlux Perfection that could be quite satisfactory, but these are at least $60 a quart for the material, but you will also need the $19 per quart thinner. You will also likely need a new brush for each coat applied.
