Dado Frustration - Long
Scott Greaves in Blackfoot Idaho
>My tale of woe revolves around a bookcase-in-the-making that is fighting me. Last night we cut the sides, top and bottom, and the shelves, and then proceeded to cut some dadoes for the shelves. I am less than happy with the way they turned out!
We have been remodeling our cabin for the past four years, and I am now needing to make the built-ins, one bookcase and two linen closets. My Wife chose the wood she wanted, some oak veneer plywood from the orange Borg. I have a nice shop, with decent tools, if I can uncover them long enough to make anything. I have been woodturning long enough that the poor Unisaw hasn�t seen much action lately, but like the trooper it is, it still works just fine. Night before last we did all the ripping cuts on the four sheets of plywood, which went really well with three sets of hands to push, pull and balance.
But last night we needed to do the crosscuts to cut the panels for the sides, ends and shelves. We started with the bookcase because, frankly, the board on the top of the stack was the right width for the bookcase! I made the first cut on the long panel with my little Porter Cable Saw Boss, and all things considered, I thought it turned out straight and accurate, although there was some tear-out. I rough-cut the ends and shelves off the long pieces using the Saw Boss, and then cleaned them up on the table saw. So far I thought we were good.
But then came the time to set up for dadoes for the four shelves. We placed the two side panels together, and measured and marked them both for location of the dadoes. My Wife then thought we should use the fence to get the dadoes where we wanted them. This is of course dangerous, so I refused. After a little haggling, I agreed to clamp a short block to the fence so that before the workpiece got to the blade it would have cleared the block. This way we could use the fence to set a consistent measurement, without the danger of binding and kickback.
All I have to hold the pieces for crosscutting is the stock miter gauge that came with the Unisaw. I felt that I had really good control of the board, but evidently something was amiss, because after the dadoes were cut, and we placed the boards together again, I was sickened by the sight of dadoes that didn�t line up. They are not off by much, the worst by about three-sixteenth of an inch. But this is not the way I want to make anything!
Yes, we will put this together, and when we get it installed in the wall, and books are on it, we will not notice. But it will always bother me that I could not do a simple thing like get the dadoes in two boards to match up.
The worst part is that I still have two linen closet inserts to make, so two more opportunities to mess up some dadoes! Please take pity on this poor woodworker, and help me to find a way to cut my dadoes correctly, so I can be proud of my accomplishment! Is a cool new after-market miter gauge, with an extended fence the answer? Should I make a cutting sled? Please jump in and save me from future embarrassments!
And while we�re on the subject, what is it about Home Depot plywood, and variations in thickness of what should be a simple, consistent dimension?
Thanks for the help, and sorry to rant!
Scott.
