Dust in my cyclone filter help.
jeff
>Hi all
I dismanteled my cyclone yesterday for moving it.
I pipe my cyclone exhaust into big canister filter.
Inside the filter was alot of debris (chips from the planer maybe).
I cleaned it out.
Seemed more like the debris was definilty chips and such, and not alot of fine dust.
What causes this? and any suggestions to fix it?
Jeff
Re: Dust in my cyclone filter help.
Paul Woolson
>Did you ever over fill your chip canister? I did that once and since the debris has no place to drop it just takes the next closest road: the filter.
Phil Thien
>Either what Paul says or a leak between the drop bit and the cyclone. This allows air to get sucked in from the wrong direction, which can carry debris into the filter.
I think I might be guilty on both.
jeff
>Thank you.
One of the reasons I just moved the cyclone was to get easier access to empty it. It does get kinda full.
Also, I found a bad gasket seal in the top of the garbage pail I use to collect the debris.
I will fix both.
Jeff
