Re: Clear Wood Filler?
Rob Stokes in North Vancouver
>Agree with the epoxy.
If you warm it (not hot, just warm - stick the container in hot water for a while)prior to mixing the two parts, the viscosity will go down and it will flow into the nooks and crannies better and faster. This means less "slump" as the thickening epoxy creeps into various cracks before it sets off and there's less chance the resulting solid will have a hollow in top.
But know also that when you warm the epoxy you're going to shorten your working time. All the more reason to use the 20-minute stuff and not the 5-minute stuff.
I over-fill the void a bit, chisel the "almost hard" epoxy off before it sets hard (you can also use an old block plane to do this), and sand the rest of the overfill off later.
Remember also that when you sand the plug down after it's popped off, you don't need a mirror finish on it. Sand it as you do your wood (220) and the clear filming finish you use on top will restore the clarity of the surface of the epoxy.
Oh - when you sand it, don't concentrate your sander over top of the plug. The hardness of the epoxy will be more than that of the surrounding wood and the soft pad on your sander means you'll end up digging a hollow in the wood.
No - I won't explain how I know this :)
Rob
