huge fiddleback cherry
Bill Tindal, E.TN
>I went to the log yard today to get some firewood. They trim logs to improve grade and the trimmings are free to haul off. They had cut a huge crotch from a cherry log. I got the log grabber operator to turn it on end and with considerable effort I sawed it into 6" planks. I will need to find something to make from it. Any suggestions. I have never been blessed with something like this before.
PS the log yard was busy today and I got some good action photos of unloading log trucks and grading logs which I will post later in the week.
Re: huge fiddleback cherry
Jim in Burlington Ont.
Missed the pic
>Hi Bill you missed posting the pic.
well darn
Bill Tindal, E.TN
Sweet
>That's going to make a few really spectacular doors for cabinet's. Resaw you've got a real treasure.
Not from Denver area...
Brian in Brighton
>Unlike that yardstick. I bought a few things from them before they told me that to fix my drain in the basement I would be jackhammering because what I wanted to do was impossible.
BTW: Nice wood!
Brian in Brighton
Fiddleback Cherry
Philip Duffy
>Well, I have one that looks like it and I wish mine were 6in thick! Yours will turn into one spectacular bowl, I would think. Mine gets to be a platter/shallow dish because there just is not enough depth to work with on a really good bowl. Best thing about mine is it is sold before it is turned! Phil
Don't count your chickens yet!
>Bill,
That is some beautiful wood. But be advised that you need to dry it carefully. Some crotches like that can form nasty cracks. Baby them until dry and by then you'll have some good ideas for their use.
Good luck!
Tom
I'm well aware of the perils
Bill Tindal, E.TN
>Any suggestions? I was going to cover the whole thing with Anchor-Seal and put to rest in the proverbial cool dry place.
Re: I'm well aware of the perils
>That's probably the best you can do. I know of no real secrets, only that crotch wood doesn't like to dry quickly. I have a friend who makes chairs and likes using crotch wood for the seats. He bemoans the heartbreak of his seat blanks cracking. If the cracks are small then there is always epoxy filler. The beauty of that wood overshadows inperfections in my opinion. Be patient and you might end up with intact beauties there!
Tom
Re: Suggestions
>Instead of Anchorseal all over (I use it too), I would apply smoking hot parafin to the endgrain + 1" only, then sticker the flitch at 1/4" gap, apply big-time weight (a full layer of 4" solid block) to the top of the stack to control the Cherry-dance, and forget it for a few years.
mm
about wax
Robin Corell in Atascadero, CA
>On the very first tree I ever milled I painted the ends with Brown Victory which is a micro crystalline wax used for sculpting. it is more flexible and stickier than parafin. It was something I had on hand and I figured it would work better than paint or the wax emulsion sealers since it was thicker and impervious to moisture.
What I failed to understand is that wood shrinks as it dries and the wax, while being flexible when warm, was still not able to shrink along with the wood. the end result was that it ended up shrinking off in large flakes.
That was the last time I have used wax. I have used BLO, scrap latex paint, old yellow glue, and acrylic glue. Of all of these I think the best is acrylic glue. The stuff I had was called Roo Glue and is awsome for glueing melamine. I had half a bottle that was vey old and too thick to use for anything that was sold to a customer so I used it up the way I use up all my old glue. If this stuff wasn't so expensive I would use it to end seal all my wood.
The reality is that I actually don't end seal most of the stuff. But what I do seal is stuff like what Bill has, and then I seal the knots, crotch, and burl areas as well as the end grain.
The other thing I would consider is rather than stickering and stacking these is to stand them on end as near verticle as possible with some spacers under the ends to keep them off the ground. I recently read that the Nakashima Co does this and have tried it on a few stray pices with good results for the free moisture stage of drying, still waiting for EM on these slabs.
Robin Corell
thanks for the good ideas
Bill Tindal, E.TN
