Veneer Damage Control . . .
s.mackay@worldnet.att.net
>I started sandin the top of the junk ( free ) sideboard. Theres a small bit of water damage in spots so some of the edges of the veneer are separated ( correct term ? ) / coming loose. Already knocked a small chunk loose on a drwaer front. BEFORE I tear up any more I'm going to be " un-manly " and ask for directions ! Can we re-glue all these edges ? I'll bet theres a restorer lurking here some where. Thanks much !
Re: Veneer Damage Control . . .
>Good Afternoon S,
I cleaned the area of delamination as best I could and reglued, cover with wax paper/sheet plastic using slight pressure, cauls and liquid hide glue applied with an artist's brush. Warm water will take care of the residual liquid hide glue. Use the liquid hide glue on the detached fragment, align exquisitly and cover with wax paper or sheet plastic and a lerger piece of flat scrap. Weight it down or clamp. The liquid hide glue has a great tack and a long open time. Work carefully and no need to rush.
George
Great ! Thank you. Slowly ? Oh, yes !
