Freud Rail adn Stile matched Bits
Howard G
>I have been getting varying degrees of tearout when using these bits, particularly on maple. I have been running them at 19,000 rpm with a fairly steady hand feed. Anybody have similar experience or suggestions on how to solve. Thanks for the help.
Re: Freud Rail adn Stile matched Bits
How sharp are they?
Ellis Walentine, Host
>I don't know how much you have used these cutters so far, but they might need sharpening. Possible?
Performance also may vary with feed speed. You don't want to feed too slowly or the bits will burn the wood, but maybe you can slow the feed a little and improve your results.
The trouble with router bits (as opposed to the larger shaper cutters with similar profiles) is their tight cutting arc, which gives them a greater tendency to tear out. Of course, larger bits require more power to run and must be run at slower speeds.
Not much help here...
How sharp are they, and how many passes?
nailshooter
>If you have the correct speed for your bits and decent wood, then as said above, watch that feed speed. On the other hand, cranky wood can mess up the most careful molding operations.
I would try cleaning the bits to shiny, then touching up the bits with a flat diamond file. If you can't get them sharp that way and still keep the surfaces flat, then they may need professional sharpening.
The other thing I would take into consideration would be the amount of bite you are taking at a pass. Some need more than others, but I wouldn't take off more than half at one pass. I like to take about 45% the first pass, 45% the second pass, then a light cleanup cut to finish.
Robert
George (Oxford, NC)
>Are you using a sled with a backer-board for the rails?
George
Howard G
>Thanks guys, the bits are new so I'll have to look at the feed rate.
