jam extensions?
jam extensions?
jam extensions?
Ernie Miller
>Used to be when you bought a window for new construction they cane with jambs that fit most 2X4 construction. So on a sunroom I'm building I buy vinal windows and they need extensions to bring them out 2 1/2" to meet the window caseing dosent look like you can screw them to the window units so I guess it will be glue. or is there an easier way? maybe even cheaper? do they make vinal extensions? Were talking 15 windows here so easy would be an option.
Re: jam extensions?
Re: jam extensions?
Bill McDonnald
>It would be a better investment to buy alum clad real wood windows.....Vinyl says that you were too cheap to do the job right.
Re: jam extensions?
Re: jam extensions?
Dave Winters
>One way is to get 16d finish nails and pre-drill for them. If you can, use a drill press and drill clear thru the edge of your EJ.
Re: jam extensions?
Re: jam extensions?
John E. in SC
>You didn't mention the manufacturer of you windows, but I would check w/ them (or at least where you bought them). Some mfrs. make a jamb extension kit - at least they do for 2x6 construction, so surely they make something to make up the difference w/ 2x4 construction.
John
Re: jam extensions?
Re: jam extensions?
Jerry Burns
>Ernie are the windos installed yet I put jam extisions on for a friend with pocket holes and screws worked great he had no problem with the trim
Re: jam extensions?
Jack Guzman from Maine
Re: jam extensions?
>Ernie,
When I install those I usually use long finish nails and predrill through the extensions. In some cases though I have built the sill and extensions into a frame,attached the trim pieces on sides and top and attached this frame to the opening as one piece.Just a little alignment,it's quick and easy.---Jack
Re: jam extensions?
Re: jam extensions?
Ernie Miller
>Thanks Jack that is what I have been thinkingsounds easiest to me
