Where hardwood lumber comes from 4- saw mill
Bill Tindal, E.TN
>Where hardwood comes from Part 4- saw mill, debarking
This is Part 4 If you have just joined us, go to the Archives and search this title to find the first 3 parts. I will depart from the weekly installment and post the several part description of the saw mill every other day of so this week.
In the old days the saw mill was set up near where the logs were harvested. There was no automation in these simple mills, logs and lumber were moved by man power, and a portable engine powered the saws. They only were able to saw a few thousand feet of lumber in a day. Now the mills are more complex, automated and they occupy permanent locations. The smallest mill in our area saws 100,000 bdft per week while the largest saws 100,000 bd ft in a day; that is about 30 tractor trailer loads of logs per day. All these mills use the same steps to convert logs to lumber. Logs are debarked, then brought to the saw or saws, and sawed into boards. Boards with bark on the edges are ripped to remove the bark. All the boards are then graded, defects are trimmed away to improve grade. Finally, the lumber is sorted and bundled by grade, thickness and length ready for shipment . The mills mainly vary in the amount of automation employed to move lumber around, the automation to determine how to saw a log for best yield and the details of the saw or saws.
It is difficult to get good pictures of a mill in operation, so most of the pictures will be of the mill at rest for they will best show the equipment. Maybe later I will get some action photos of some of the mill operations. The mill pictures were taken at two of the smallest mills in the area because they are closer and I can wander around them at will.
Debarker (debarker) The bark of the log accumulates all sorts of saw-dulling grit during skidding the logs out of the woods and on the log yard. This grit would dull the saw prematurely and result in lost production. The mills remove this bark with a debarker, a machine that comes in several varieties. Logs are loaded onto a live skid way with a forklift or log grabber like what was shown at the log yard. The live skid way is a series of parallel chains like on a bicycle that rotate over sprockets and move logs or lumber forward upon command of the operator. We will see an example later in the mill.
The operator sits in the green house on the right. A log is brought forward by the moving chains and dumped onto the cogged wheels, half of which are seen in front of the small log which has just been debarked. The large oak logs are still on the skid way awaiting debarking. These cogged wheels capture the log on each side and upon command of the operator they turn and rotate the log under the debarking head which is the part to the far left and show in close-up in the next picture. The debarking head is moved across the log on the track in the foreground. The wires overhead power the debarker motor.
