Shop lighting: dead ballast
Bob McGovern
>I could use some help finding the right ballast for a recessed fluorescent light fixture. It's a 48" Lithonia with four of those slim Sylvania Octron/Ecologic 32W bulbs (2 pins each end). The dead ballast has as its only markings "Standard: REL-4P32-SC". Would any T8 4*32 ballast do? Two yellow wires, two red, and two blue; usual line-in white/black.
Having trouble finding this exact model. Advise and/or sources? Danke schoen.
Re: Shop lighting: dead ballast
Re: Shop lighting: Many sites -Google
Larry Clinton At Frankfort (Central)., Indiana
>http://www.blackenergy.com/store/index.php?main_page=index&cPath=61_66
Check the above link. $17.95 Item listed near bottom of page shown. I did a Google search - found many places that sell them including Grainger (high price) Ebay, above site, and others. It is a standard 4 bulb T8 electronic ballast.
Hard to find, curious why
Tony Shaftel
>One of my 4-T8 electronic ballasts quit a few weeks ago and I couldn't find any at the three hardware stores near my home. I found them at Lowes and HD but there were relatively few on the shelf compared to the last time I looked a couple of years ago and they were like $26 instead of the $18 I recall (could be wrong). All the stores had plenty of the non-electronic T12 ballasts.
A guy in one of the local stores told me they didn't stock them because they didn't move. Something about the 'first generation had problems.' Is that true? They seem to be used all over the place in commercial establishments. Anyone know the story?
Gary Camp, Bend, Oregon
>That is a number for and Advance brand ballast, you may only find them at an electrical wholesale house. The T-8 4 tube ballasts I use at work have that number.
glc
Re: Hard to find, curious why
>In many cases the light fixtures are almost as cheap as the ballasts. The 2 bulb T8 fixtures often sell for less than $10 (without bulbs). Not sure of the 4 bulb units. I used to contract electrical work for a small chain of NAPA stores & shops. It was much cheaper for me to replace the fixtures than replace the ballasts in their businesses. In my shop all my lights are 2 bulb T8 / T12 with electronic ballasts. They are hung with short chain and plugged into switched outlets on the ceiling. I can change out a fixture in very few minutes - for less cost and a lot less time than replacing the sockets or ballasts. Could be why they ballasts don't sell well. I only have one 4 bulb fixture (in my Utility room) that would be economical to repair - as it was somewhat expensive with the cover & trim.
Re: Hard to find, curious why *LINK*
Bob McGovern
>Yeah, my local hardware store had a similar ballast, but it was $45. The whole recessed fixture, including four bulbs, cot $30 new. But Googled the exact ballast product number; Energy Federation Incorporated had the exact replacement article for $18 plus shipping. That's a bit more reasonable. These ballasts don't live very long; suspect my weird electricity & my shop power surges aren't kind to them.
EFI
Quality ballasts should last 40K hours
Matt Williams Arlington WA
>I install these commercially and we warranty the lamps for 10,000 hours and the ballast for 40,000. This works out to about 5 years in a commercial setting. Should be about two lifetimes in your shop.
My cost for the ballast yor describing is about $12. By the time you get the middle man markup $18 is about right.
Re: Quality ballasts should last 40K hours
Bob McGovern
>Matt: I suspect Lithonia isn't using the very finest ballasts in its utility grade troffers. This may have been just a bummer unit, too.
I can think of two other potential causes of early death: every time I start the PM66 or air compressor, there's enuf voltage drop the lights blink off briefly. Several sources indicate frequent cycling is very hard on ballasts. Second, I run my shop on modified sine wave power, which confuses mid-complexity electronic devises pretty badly. Wonder if voltage & current surges -- or the chronic low peak voltages (c. 105/207V)-- will fry these things afore their time? They did live three years of pretty steady use, 12 hrs a day.
>My experience with a lot of inexpensive fixtures has been shorter ballast life, cheap but not really thrifty. I have changed over a couple of whole buildings (t-12 mag to t-8 electonic) about 12 years ago. With one building I had a fairly high faliure rate the first couple of years. It may hve been power issues or problems with ballast at the time. I have changed brands and we have made improvments to to our 24kv power supply. I have changed to using multi-voltage ballasts recently (less parts inventory) but I haven't been using them long enough to know if that change will affetct ballast life. Most of our fixtures are now t-8 electronic, but we still have a couple building with t-12 mag fixtures, those get converted as they fail.
glc
Most any should work but
>I've swapped out ballasts from t-12 fixtures and replaced them with T-8 ballasts (and bulbs). It takes time but is simple to do.
There are 2 grades of ballasts for sale around here: consumer and industrial. The Industrial ones are more expensive - like double the cost. I suspect they will last longer because of better quality (read cost) components, insulation and cooling.
The better components will likely handle surges much better. How they are mounted will affect how well they are cooled in use which dramatically affects the life of electronics.
One more thing to watch - some are designed for 208 volts. Don't get these for standard wall voltage.
Around here, the cheapest 4-tube T-8 fixture I could find was around $55. The 2-tube ones are roughly 1/2 of that. That includes the (hidden) rebate from the electricity company (my daughter works for them, in energy conservation, and explained the deal to me). A quality 4-bulb ballast was on the order of $30 while a cheap one was a lot less, last time I priced one.
You are probably seeing the industrial ones in the store which accounts for the cost difference. By the time I factored in my time to replace the ballast, I decided the extra cost for the commercial one was worth it for me.
I replaced some for a retired woman on limited income (volunteer work) but chose the low cost solution for her because she did not use the lights much. Actually we replaced the fixtures for her since the fixtures needed replacement - actually the old ones were a fire hazard.
