More Info?
Curly Smith
>Do you have more information about the video sender? It's not clear if you're talking about old technology or the new version.
The old technology is represented by these two similar devices:
Enjoy cable TV in any room in the house with X10's Video Sender!
($50)
"Your wireless Video Sender's included remote lets you change the channel on cable right on your second TV without getting up, and more! Control DVDs, watch recorded programs on your TiVo or DVR, and if you already use X10 light or appliance modules, you can control those too � and all on an ergonomic remote designed for easy handling. Strong 2.4 GHz signal travels from your wireless Video Sender through walls and floors up to 100 feet away � that's all the way across the house, or from the basement to the upstairs TV!"
Transmit TV Signals Throughout Your Home Without Wires ($70)
"The Leapfrog Wireless Audio/Video Transmitter and Receiver System is easy to install, requiring no tools or no complicated (or expensive) cable installation. By transmitting across the 2.4GHz frequency band, it gives you the clearest signal with up to a 150' range. Its signals penetrate walls, doors, ceilings and floors without any interference. Multiple transmission channels allow you to select the best signal possible, as well as eliminate interference with other household products that may also use 2.4GHz technology."
This is the new version:
Send Wireless Signals to Control Components in Another Room ($155)
"If you have always wanted to distribute audio and video to a second room but have avoided doing so because of the cost and difficulties surrounding running cables, the easy answer has arrived. The 5.8GHz Wireless A/V Sender with I/R Extender transmits clear audio and visual signals over radio frequency, so there are no wires to run, and since this is the first ever 5.8GHz-band product of its kind, you'll avoid the interference associated with crowded lower-frequency band applications, such as 802.11b wireless LAN, cordless phones, and microwaves. You'll even be able to control your components using your existing remote, since the 5.8GHz Wireless A/V Sender includes an IR extender, transmitting your signals to the receiver in the room with your components."
If I were buying one, I'd get the new version because of the potential interference at the lower frequency. Take it with you when you move and use it in your new digs. However, if you want the old version I'd troll the clearance (open box) section of the Smarthome website and save 10-20% on one that somebody bought and returned. I've never used any of the above but I've bought a fair bit of stuff from Smarthome (and some of that was items returned by other customers via the open box / clearance section of the website).
