miter gauge setting on table saw
tom morrison
>this is a rookie question- i want to cut a piece of 1x6 to a measurement of 9 inches on one side and 11 inches on the other side. ( a slope of 2 inches for sides to a birdhouse)
two questions:
1. how do i figure out how to set the miter gauge on a table saw to cut this "slope" of two inches?
2.once the sides are cut with the 2 inch slope and attached to a flat back, how do i calcuate the corresponding bevel to cut on the top which will fit flush with the back.( no gap)
thanks
Re: miter gauge setting on table saw
Al Stokka - Cambridge, Iowa
>Tom,
Requires trig.
If your 1x6 is actually 6 inches wide, set you miter gage to 18.434�
If, as I suspect, your 1x6 is actually 5�" wide, set your miter gage to 19.98� [20� should be close enough. ;^) ]
Fro the cut on the top of the birdhouse, the angle will be the same as the angle of the side (18.434� or 20�). Set the blade bevel to that figure.
Al
