Fast & accurate countersinking?
Tom MacGregor
>I need to countersink a couple thousand flathead (sheetrock type) screws into luan and 3/8" CDX with 2X4's underneath. I know how to set the depth on a drillpress, but this has to be done with hand battery drills. Does anyone know of a fast accurate way to set the depth? I can't rely on the screws to set properly without countersinking first and can't risk having them blow through the plywood.
Re: Fast & accurate countersinking?
Jim in Burlington Ont.
Router
>A router will do it better than anything else IMO.
Dale Lenz
Re: Fast & accurate countersinking? *LINK*
Dale Lenz
>See link below OR for a poor man's thingy: put a slightly oversized pipe of needed length over the bit and drill away.
Drill guide
Use a jig
>You can use one of the standard countersink/drill combo units (like the snappy units, for example) and set the depth with a home-made jig.
I think that a piece of PVC pipe (or clear plastic pipe) could be used to make the jig - just pick a piece whose inner diameter is bigger than the drill bit/countersink. Cut a piece of hardwood and mount the piece of pipe to it so the wood acts as a stop for the chuck. Drill through the wood piece and the pipe. When the chuck presses on the wood, you are done - depth is correct (assuming the pipe is cut to appropriate length.
You might need to replace the wood piece after a while because of wear, but using a good hardwood, such as hard maple, it should last a long time. If you use plastic pipe only, the chuck will heat up and deform the pipe after a while.
If you can not see where the drill bit is going into the piece you are drilling, go to a plastic supplier and get lexan or acrylic pipe.
Paul in NJ
COUNTERSINK SET
Bob Burnet (NW Florida)
>I would recommend a drill bit, with countersink, and collar. The collar is adjusted to get the countersink to go to the exact depth you want. Get the right diameter drill bit and countersink for the size screws you will use. There are several manufacturers such as Fuller, DeWalt and others. Scroll through the pages in the link for countersink bits and collar that goes on the shank of the countersink.
http://www.snappytools.com/products/other.asp
>I have been screwing down subfloor using "Drill Bit Stop Collars" I picked up at the local Woodcraft store. $7.99 for set of about eight ranging from 1/8" to 1/2". They are rings with a set screw that clamps onto a drill bit. I am using the 3/8" bit with the collar set just at the tip. I use a battery powered drill to counter sink the holes and a battery powered impact driver to drive the screws.
Jim Dillon
>Tom,
If you really need a consistent countersink depth, then the drill guide that Dale linked to would work well. I've had mine for 7-10 years and it is surprisingly useful. Did thousands of plug holes in hardwood floors, installed dead bolts and locks in doors and drilled in the middle of large sheets of plywood. While the drill guide has built-in stops, I don't trust those to not creep and change the depth setting. So I place regular washers over each guide post to adjust the depth of drill hole.
Somewhere I've seen a homemade drill jig that looks like a woooden clamp surrounding the drill near the front. A hole is drilled in the face of the clamp through which a dowel is placed. The dowel is adjusted until the right drill depth is achieved. A thumbscrew tightens the dowel in place. I hope this makes sense. The problem I see with this arrangement is keeping the clamp tight to the irregular drill body.
Hey, maybe a solid wrap of duct-tape holding the dowel in place would work? 8-)
How consistent do these countersinks have to be? Using your eye and the tactile feel between you and the drill can give pretty good results. Plus you could hold a screw in the other hand to check for the right width of countersink; if the width of the countersink hole is the same as the width of the drywall screw, then it should be flush with the surface. Sure would be a lot faster way of getting the job done. My 2 cents before I've had my full cup of coffee, so beware.
Jim
