ADVERTISE HERE - FREE TRIAL
Need help with making doors for cabinet.
Alan Tolchinsky
>Hi All, I'm making a storage cabinet in my bathroom and need help with making a door for this. The unit is about 7 feet tall by 16" wide and will have two doors. I want to paint the doors white. What type of door would you use here and how would you trim out around them? Thanks. Alan
Re: Need help with making doors for cabinet.
Lee Schierer - McKean, PA
>I would make a face frame to attach to the wood you have in the holes. This frame would be 1-1/2-2" wide. Then make either half or full overlay doors with raised panels to match the door you see in the photo. Since you are painting the frames and doors, use poplar. Use erou style hinges so they don't show when the doors are closed. Sand everything after the first coat to remove the fuzzies. I would paint the raised panels before assembly so that seasonal contractions do not expose bare wood around the edges of the panels. Because the doors are tall you may want to consider splitting the height with another cross piece in the doors to make two raised panels in each door. It is hard to tell from the photo how this would look.
Lee
I'd agree with Lee, repeat the elements....
John in New Mexico
>of the larger door, at least enough to catch the gist of it. Faceframe on the box, though I find it easiest to attatch the frame to the box and then install both at once. Personally, I like inset doors rather than overlay, but thats just personal preference. On painting, buy good paint, its well worth it. The borgs are selling junk that gives latex a bad name.
John
Re: I'd agree with Lee, repeat the elements....
Alan Tolchinsky
>Thanks John and Lee for your replies. All the suggestions make sense to me. I like inset doors too especially for this application. What type hinges do you use for inset doors? And what kind of door stops are needed? It seems that you'd need something to stop the door from closing too far into the cabinet. Thanks again. Alan
Yes, you need a stop....
John in New Mexico
>I usually end up with a little block of wood with a magnet set in it, and one of LV's washers on the door. Hinge is just a standard mortise hinge, small version of what you find on a door. Bit more of a traditional look to the finished product, and once you get used to installing them there's no going back. Nothing wrong with a good overlay hinge though, especially if its one of the wrap around ones with a screw 90 deg to the others.
John
Don in Northern Arizona
>Alan,
I had a similar situation to yours in our guest bath. Not painted, and the door is actually part of the vanity, but otherwise quite similar. I would definitely vote for inset doors, otherwise you have the raised face frame and the overlay door sticking out further. I went with an inset door with 2 x 2 1/2 in hinges. My door is 51"x16" and this works well. I also used the magnet catch on a block at the top of the door.
HTH,
Don
Magnetic catch
Hinge.
Re: Hinge.
Alan Tolchinsky
>Don, Thank you very much. That is a beautiful job and I like your idea of the inset door. I don't want my door sticking out any more than I have to. Thanks again. Alan
