>The basement/shop is zoned separately from the rest of the house. Haven't really had to turn on the AC as of yet as it is cooler than the rest of the house. The humidity is rising however. We have one Hampton Bay 16 pt. dehumidfier. I'd like to get another dehumidifier. I don't mind emptying them as it gives me a source of water for the tomatoes. The Hampton Bay typically fills in a day or less.
>The ones I've seen usually have an attachment that you can run a hose to a drain. Maybe you could find a way to drain it into a larger container so you wouldn't be forced to empty it as often.
I've got two Hampton Bay units, one in my guitar shop and one in the basement, and they do a fine job.
>Get one that is quiet. Our basement unit is so noisy, I hate to have it running if I'm down there. Also, get one that won't ice up when the temp is below 68�.
>Draining to a floor drain is the best idea. When your humidifier shuts down due to a full tank, humidity will regain quickly.
Kinda like heating your house with wood. Forget to feed the fire once in a while and the moderately sized wood stove cools down and the house goes cold.
The comments on the need for a direct drain for dehumidifiers in your basement are right on target. The condensate pump works and is a low cost solution if you don't have available sewer drains in the basement.
The bad news is that if your basement is much over 1000ft2, you will probably need to eventually purchase 2 units to do the job. I tried to make it work with a single 60 pint per day unit from LG and during the summer I could not really get below 50% and hold it. My basement has no visible water infiltration, is roughly 2000 ft2, is totally under ground, and is fairly new construction in a suburb of Chicago that has very strict and detailed building codes.
I now use a 60 & a 30 pint per day units (both LG brand from the Borg) and maintain a RH of 35 to 40% year round. Prior to adding the second unit I still had some rusting problems. With the 2 units in operation for the last year rust is not an issue and the basement is dry enough that my better half can store linens in plastic containers without any milldew concerns.
>With the watering restrictions, I would really like to conserve the water from the dehumdifiers. I have an existing condensate pump on the HVAC system. I will get a second dehumidfier and hook it up so it will drain into the condensate pump. If the LG works, I'll plan on getting one of those.
