Dado or Groove
>If the material is Man Made and has no grain can you call a groove a dado?
Stephen
Dado or Groove
Stephen
Re: Dado or Groove - How about calling it a "Rut"
Larry Clinton At Frankfort (Central)., Indiana
You can call it whatever you want...
John in New Mexico
>the question is do you want to be understood?
More seriously though, I wouldn't think that the word groove is sufficiently descriptive. To me the word dado has more to do with the shape of the cut than the material its cut in.
John
Re: You can call it whatever you want...
Jesse in New Mexico
>Hey John,
I agree that everybody knows what a "groove" is. I think,though, that a groove is supposed to run with the grain and a dado across the grain.
For grainless material, I like the term the Aussies use a "trench" ;^)
could be...
John in New Mexico
>I do like trench though.
Back to the trenches!
John
Ol' Norm ALWAYS says dado . . .
s.mackay@worldnet.att.net
>with biscuts . . . for EVERYTHING ! God bless his heart .
or, in this case, a "housing" (no grain direction)
Andrew F in Australia
>Except for the New Yankee Workshop's influence and the American mags, the term 'dado' wasn't common a while ago.
It is now here,
However, the correct terminology here is that a trench runs across the grain and a groove runs along the grain. The generic term for the recessed joint is a housing.
Back to the trenches,
Cheers,
Andrew
You forgot the brad nails!
John in New Mexico
Plow or Trench?
>This is from a TOH episode when Mr. Silva called a groove a dado when it ran along the length of the material, PVC in this case.
I was taught a groove or plow ran with the grain and a dado or trench ran across.
Now lacking grain direction in man made materials does the same convention apply? I would think so. It is just easier for everyone to understand if the proper terms are used.
Stephen, splitting and pinching hairs
Hair splittingly
>Hi Stephen,
Trust that all is well.
As I alluded to in the post above, here it's called a housing when there isn't a grain direction.
Can't answer for the US terminology, however. Perhaps Sgian Dubh or others may know the local convention.
Hair splitting, I agree, but 'housing' is the term here.
Cheers,
eddie
Until the glue dries
I suspect...
John in New Mexico
>That this is a case of language evolving a bit. Presumably the reason for different words for a cross grain vs long grain groove would be that they required different methods to cut (with hand tools), and different methods to join and not fail due to wood movement. The requirements for making a successful joint could be communicated between workers by the use of the proper words.
With the advent and widespread use of grainless materials, dado cutters (& routers and shapers) that don't behave much differently on any of these materials, and largely self educated (and TV educated) workers, the distinction between dado, plough, groove, trench, and housing has become largely irrelevent. I would guess that the reason that "dado" seems to have become the most commonly used word -- in the US at least -- is because the most common way to cut one here is with a dado cutter on a table saw.
Semantically,
John
( snicker-snicker ! )
Then does he remove the brads?
