OT: Critters under the shop
David Hay @ Denver
>Lately I've had all manner of critters burrowing under my shop (Tuff-Shed building sitting on gravel/dirt) First a family of rabbits and lately a fox and her pup. The foxes appear to have moved on, but the left kind of a mess with several holes dug under the perimeter of the shop. Any suggestions for how to fill these holes in such a way that I won't have rabbits moving back in within a few weeks?
Thanks!
David
Re: OT: Critters under the shop
vlparisian in Houston
>This is usually a two person operation.
Try mixing up one bag of portland cement with about 12-15 gallons of water in a heavy duty plastic garbage can. Use one of those long paint stirers from the borg that you chuck up in a half inch drill motor. Start with the water and add cement slowly until bag is empty. The resulting mixture should be about the consistancy of latex paint.
Before you mix the above. Fill holes as far as reasonably possible with loose gravel coarse sand etc. If concerned about the mixture running away from you when you pour it(ie not running under the shed), just form some dams out of soil to contain the mixture on the ground around the shed.
Pour the mixture into the hole over the loose gravel and sand. The water and cement mixture will fill all the low areas and can flow a long way so be ready to adjust your dams as needed. If you spill some just let it stand over night and pick it up in the morning, or wash the mixture away with plenty of water.
Repeat mixing and pouring until you feel you are done.
Fun with grouting 101
Victor
paul in AZ
>As part of filling the holes, dig a trench around the shop and lay in some galvanized wire mesh. Part of it vertically and tacked to the shop wall and part at 90 degrees extending out away from the shop horizontally. About a foot deep and an equal distance out from the shop should deter future diggers. Worked for me.
Phil Joines Krum, Tx
>That's what we use to keep criters out of out avairy. It deosn't need to be burried deep, but needs to extend out at least 18", 2 foot is better.
Gravel it bac and add chicken wire near the top
Scott in Eastern Iowa
Ranbir Chawla - Castle Rock, CO
>We have the same issues with rabbits in our feedroom in the barn. Our rabbits chew right through the wire fencing we'd lay, so we gave up and buried 12" metal flashing (comes in rolls) straight down along the inside edge of the room. It's the only thing that's worked so far. You might also try buying some cheap hay from someone out your way and building what we can a 'rabbit distraction home' in the corner of the lot away from the shop. We open that up 2-3 times a year and our red-tails see us do it and come and feast on the critters for a few hours. Might give the foxes something to do as well.
Hope that helps.
Ranbir
BTW, if you leave a car/truck outside, make sure the rabbits don't start chewing @ hoses and wires, DAMHIKT.
