OT - Virtual LPT Port for USB printer?
Ron in Drums PA
>I just installed a new laser printer for the office and it is connected via a USB port on a XP Pro System.
I have one old program that I use daily (It works so why fix it) that will only print to a LPT port
Does anybody know of a virtual LPT port for a USB printer.
I did a google and all I found was hardware, I need some type of software to do this
TIA
Re: OT - Virtual LPT Port for USB printer?
Good question.... perhaps a trick
>I work with a client that still uses a system that is DOS based and requires the use of LPT printer ports.
The printers are on the network so we use the NET USE command......
NET USE LPT1 \\SERVER\PRINTER1NAME /Y
NET USE LPT2 \\SERVER\PRINTER2NAME /Y
NET USE LPT3 \\SERVER\PRINTER3NAME /Y
I'm REALLY not sure if this would would work, but you could try share your USB printer on the network, and then connect to it.
Example:
NET USE LPT1 \\YOURCOMPUTERNAMEHERE\YOURPRINTERNAMEHERE /Y
Happy Woodworking!
Curly Smith
>This has worked for me:
(Method A) A simple method for Windows 2000 and XP only (not for Windows Vista): .
a brief excerpt:
"This method works with any Windows 2000 or XP computer, but because it relies on the networking features in Windows, you must either (1) have a system that is always connected to a network (which can be an Ethernet or wireless network, or an always-on cable or DSL connection), or (2) install the "Microsoft Loopback Adapter" software which tricks your computer into using its networking features even if it is not actually on a network. You can install the Microsoft Loopback Adapter software by following instructions elsewhere on this page."
Hey... it works.
>I figured I better try it, just to make sure..... and IT WORKS!
If your computer name or shared printer name has any spaces in it you'll need quotes.
START > RUN > cmd
NET USE LPT1 "\\Ron Computer\Shared Printer" /Y
otherwise
START > RUN > cmd
NET USE LPT1 \\RonComputer\SharedPrinter /Y
To test it you can do this:
START > RUN > cmd
DIR >LPT1
and a DOS directory listing should print out to your printer.
Let me know if this works for you.
Happy Woodworking!
Ha, ha, ha.... funny, it's the same method ;)
>I have never done it before Ron asked and now I see that there's a whole webpage dedicated to explainig it. Neat.
Happy Woodworking!
Re: Hey... it works.
Ron in Drums PA
>Thanks Mark
I already tried
net use lpt1: \\computername\printersharename /persistent:yes
and get a System Error 66
The "persistent" is used so I don't have to retype the cmd every time I log on
More details....
>The /Y at the end of the NET USE command is the same thing as /persistent:yes
The System 66 error indicates it can't connect to itself over the network.
So what exactly are you typing? What is your PC's computer name and the shared pritner name? Do you have Windows File&Print sharing turned on? Are you sharing the printer?
On my test PC here, I use:
NET USE LPT1 \\XW4300\LJ1320 /Y
DIR >LPT1
and it works like a charm.
Happy Woodworking!
NET VIEW
>What do you get when you try:
NET VIEW
and then
NET VIEW \\yourcomputer
and then NET USE
Happy Woodworking!
They stole your idea before you thought of it...
Curly Smith
Re: Mark, they're reading your...
Al Stokka - Cambridge, Iowa
>Mark,
They're reading your brain waves! Did you forget to wear your aluminum foil hat? Don't do that!
Al
But, but,but
Ken Garlock, Collin County Texas
>why not just define a local printer?
It is USB device not ethernet, to start with. XP Pro should have already detected the printer at boot time.
Just run the 'define new printer' lizard and call the port LPT. Windows already has LPT1/2/3. Call the port LPT and click next. The next page will give you a list of printer makers and devices. Select your device and click right along.
So, what say you....
Ken
Thanks Mark & Curly Joe
Ron in Drums PA
>I found a program called dos2usb that made my life simple.
Thanks again
opps Curly Smith
Ron in Drums PA
>I wish there was a way to fix spelling errors
Sorry Curly Smith
