Pocket-hole jig
Howard Pollack
>I'd like to buy a pocket-hole jig, the initial use would be to make plywood cabinets. Kreg seems to make several, and I imagine that others also make them. I'd appreciate thoughts and suggestions. Thanks _Howard
Pocket-hole jig
Howard Pollack
Re: Pocket-hole jig
kkaneoka
>I bought the Kreg Rocket Jig and really like it. Now that I know how fast and easy pocket holes can be (given the right situation), I plan on buying the K3 Master System (or similar) to make a bunch of faceframes for some new cabinets. I'll keep an eye on your thread to learn more from the other responses.
I have Kreg
Lee Schierer - McKean, PA
>I have the original Kreg die cast jig. I bought it about 8 years ago. It has worked very well and still has many years of life left. I also have one of their newer plastic clamp on jigs and it works well in those situations where I can't use the die cast one, such as adding a hole on an assembled cabinet.
Lee
Re: Pocket-hole jig
NickB
>I've got the Rocket and the Mini. Both work well (for my hobbiest use), and compliment each other. There is a new version (which looks like a replacement to the Rocket) which I'd get if I were buying one now (tool-less adjustment for different workpiece thicknesses).
Nick
Re: I have Kreg
Michael Wangler in Rochester, NY
>I bought a cheapo pocket tool a few years back. I experienced metal shavings, poorly drilled holes, inaccuracy and frustration.
I have since purchased the Kreg pack and now I like using pocket holes. Buy the Kreg kit - Any one of them.
Re: Pocket-hole jig
Biomaqn
>Short of the Festool Domino, this is the fastest system I have used for assembling cabinets. Works very well, but best used I feel for more utilitarian projects such as cabinetry as opposed to a Queen Ann Highboy..
I've Got One Also
>Good Afternoon Howard,
The Kreg's utility is well worth the money. I've had mine for years, and it is the same as Lee talked about. I use it mostly for face frames, and framed dust panels for multi-drawer cabinetry. Its all high quality.
George
