OT--diagnosing bad fan motor
Geoff in Madison
>I have a dehumidifer where the compressor runs, but the fan does not blow air across the coils.
Sources online and local shops have told me that it is either the fan or the switch.
How do I diagnose if it is the fan? I'm reasonably handy with electricity, but don't have much experience with appliances/ small electronics.
I've taken the machine apart and have the fan out. It is a 2 speed fan.
It has three wires going into it. Black wire into one side of the winding. Red and orange into the other side of the winding.
Using a continuity tester, current flows through the black and red to make a complete circuit. No circuit is made with any other combination of wires.
I found this thread with discusses replacing the thermal cut off fuseable link. Although mine is a Comfort-Aire, the pictures are of the machine that I have (neither Kenmore or comfort-aire make their own stuff---these are all made by LG)
http://forum.doityourself.com/showthread.php?t=177549
http://www.flickr.com/photos/91401998@N00/sets/72157594217636514/
any advice would be most appreciated.
Geoff
Re: OT--diagnosing bad fan motor
Re: OT--It's bad
Bill Turpin in WNC mountains
>Two speed with three wires should have continuity between all leads. Blk to white is probably high, red to white is probably low. Your motor is open.
Bill
Re: OT--It's bad
Geoff in Madison
>Bill,
thanks for the confirmation. I thought that it was, but wanted confirmation before I ordered non-returnable parts (since this part is about $35)
Thanks again,
Geoff
Re: OT--It's bad
Curly Smith
>You can test the thermal fuse with your multi-meter. If it's blown you can buy a replacement for $5-$8. If you can't test it in the motor simply cut it out and test it. Or, maybe that's what you meant by a replacement part...
FWIW - I've had a number of similar motors fail over the years. Generally the lubrication fails making the motor difficult to spin, causing it to overheat which blows the thermal fuse. If you replace the fuse be sure to apply some grease to the shaft and bearings.
Re: OT--It's bad
Geoff in Madison
>Thanks, I'll test the fuse first. When I took the motor apart there was a large amount of greasy fuzz in it.
