Cutting a circle, WITHOUT a drillpress?
Scott in Douglassville
>Hi, all -
Ok, I need to make a 3-9/16" hole, centered in a 9" square board. Set up my circle cutter, and was about to hit the switch, then noticed my stinkin' benchtop DP has only a 4" throat! Guess the easy way just flew the coop.
So now I'm thinking I'll scribe some witness marks on a board, drill the hole in it, then center the board (using the witness marks) on the 9" square, drill a starter hole, and use a router with pattern maker's bit to rout the circle. Think this'd work? Or is there an easier workaround? Short of buying a real drill press...
Thanks,
Scott
Re: Cutting a circle, WITHOUT a drillpress?
Lee Gordon
Lee Gordon
>Can you use your circle cutter in a hand-held drill?
>Scott you've got the right idea. Drill a hole in a smaller board. Then hot glue or double stick tape that board to the 9" board and then use a pattern bit. Being a turner I would simply mount the board on my lathe and turn the opening.
>Against my better judgment, I tried that, Lee. Thankfully in scrap. Not a safe idea...
>John, my lathe theoretically can swing 12", but I know better than to try it. These boards are sold and paid for; pattern bit it is. I actually found some old 3/8" plexi that I scribed lines into and cut the holes in. Laying out the centers on the boards now, then I'll rough the opening with a jigsaw and double stick tape the patterns down.
Curly Smith
>I assume that you're using one of these Circle Cutters ?
If so, I'd bump the size up enough to accommodate a guide bushing (like one of these Brass Router Bushing Set and then just cut the circle template and attach to your larger board with hot glue, double stick tape, screws (if on the back side) and rout the circle.
If that's what you meant, then yes it would work, and it would work very well.
Re: Cutting a circle, WITHOUT a drillpress? *LINK*
albertabob
>If you need something cheap this will do that job for you.
If you are really on a budget just drill a hole in a peice of 1/4" material big enoung for you bit to fit through plus a router busing and another small hole for a short nail to center the plywood jig on your stock.
Smack it on your center point with a hammmer and turn your router round dropping a few mm each pass until your are through.
plexi circle jig
Re: Use a Circle Cutting Router Base
Jay St. Peter - Southern MD
>I'm not sure about that exact jig, but sometimes those kind of jigs won't do a radius as small as the one Scott is talking about. I made a subbase out of scrap that is the best solution I've used for small round holes (used to do lots of speaker making). I used a CAD program to draw concentric circles every 1/8" up to the maximum diameter I was interested in the jig working for. I glued that to a scrap of MDF and used the router subbase as a template to drill the mounting holes for the new subbase. I then drilled a 3/8" center hole so I can use a 1/4" bit to do the cutting. Now I use the concentric circles as a template to where to drill pin holes in the subbase. I use a small broken drill bit as a pin. I tune the hole size by drilling a slight spiral pattern of holes. It sounds like a hassle, but I probably spent 10 minutes making it and can get an exact size circle very quickly. I made mine do up to 8" circles as that was where my sliding pin type jig starts working.
Only if you have a death wish ;-)
Dan Donaldson
Success!
>Thanks, guys. I drilled out the holes in some 3/8" plexiglass I had laying around. Scribed witness marks to center the circles. Drilled them on the drill press with the circle cutting fly cutter. Marked the witness marks on the boards (which are s'more three-piece breadboard-ended lensboards for a honkin' big camera and lens) and double sided-taped the plexi down. Drilled a started circle and routed the hole with a top-bearing pattern bit. Other than overthinking, took just a little bit longer than using the fly cutter.
Thanks for the input!
Scott
Perfect Circle Sanding Jig. *LINK*
Dave Thompson
>fwiw, I posted a write up on this a while back...
enjoy,
Dave
