REAL MILK PAINT
Finishing Padauk
Finishing Padauk
Finishing Padauk
Larry Marker in Alabama
>I'm building a couple table lamps for our bedrom out of padauk. Does anybody have a fav finish for padauk? I'm leaning toward wipe-on poly.
Larry
Re: Finishing Padauk
>Padauk will darken to a very deep dark red over time. Any oil will make it look muddy and murky. Use a water white solvent spray lacquer. If you don't have a spray outfit, shoot it out of a can, followed by a rubout with 0000 steel wool and Butcher's Wax.
Clint
Yes, go with oil based
Michael Dresdner
>Clint is welcome to his opinion, but I totally disagree. IMO Padauk looks vastly better with an oil based finish than with water white lacquer or clear waterbased coatings. Clear finishes that have no amber cast can often make richly colored woods look pale or washed out. Rather than being muddy, oil brings out the depth and richness of padauk and many other woods as well.
I would go with what you suggested, wipe on poly, not only because it will look great, but because oil based polyurethane is more durable than nc lacquer in several aspects, including heat resistance, water hold out, plasticizer migration resistance, and chemical and solvent resistance.
