green speckling on cherry
John McCullough
>I have cherry lumber dry to 8% and I was working the surfaced boards for a cupboard. After glue-up of sides I sanded with 120 grit and sprayed the wood with a spritz bottle that I have used before with no problems. It was tap water but I have used this many times as well. After air drying the sides I prepared to sand the raised grain and found a random green speckling on the boards. Sanding with 120 grit did not seem to touch it. It appears like copper corrosion in color. It seems to appear like pepper in size and it is through out yhe surface. Any ideas?
