OT replacement window
J Runchey
>My BIL just put in a vinyl replacement window and is wondering about installing a shade screwed to the vinyl. Will it hold screws, or do you need something special?
J Runchey
Re: OT replacement window
Ron Hildreth, Alta, Iowa
>If the window was a high quality window, such as Anderson or Pella, it's more than likely a wood window "clad" in vinyl, and shouldn't be a problem holding a screw. You'll know after drilling the first pilot hole. If no saw dust is produced and the bit suddenly sinks very easily, putty the hole closed and forget the shade.
Ron in Iowa
Howard Norman-Prescott, AZ
>If it is a vinyl window I doubt that it will hold screws. Why not epoxy on a mounting bracket?
Howard
Hahahaha...
Mark Nowicki
>No.
Mark
