flattening waterstones *LINK*
charlequint
>Hello everybody,
I recently purchased 2 new waterstones (5000 and 8000 grit naniwa industry stones, japan woodworker sells the 10000 grit stone from this company).
Normally i use a DMT duosharp to flatten my waterstones, i've got a 200 grit grey sandstone, a 1000/3000 grit cerax ceramic and a Belgian brick (around 6000) and haven't had any problems with the diamond stone.
I tried to flatten my new stones and i think i ruined my duosharp stone. The surface (600 grit) suddenly has some shinny spots, which left wet starts to rust.
Afterwards i tried to flatten them with the 200 grit grey sandstone and this one flattens the new 'ceramics' stones without a fuss, but leaves a rather rough surface.
How is it possible that a rather soft stone can remove material and an extremely hard surface (diamond particles) doesn't ?
Another problem i have with my new stones is that they glaze over really quickly, is this normal ? Is there a trick to prevent the glazing of waterstones (nagura stone ???).
George
japan woodworker naniwa stone
Re: flattening waterstones *LINK*
I suggest a coarse diamond stone.
Forrest Addy
>I suggest a coarse diamond stone. Use it for no other purpose. Do not usee finer than 320 grit. You need the height of the grit to reach through several successive bonds to break out clumpf of high abrasive. Use alternating diagonal or orbital motion.
Using finer diamond grits allows the tough surface of the water stone to get too close to the nickel bond at the root of the diamond and lap it out.
Personally I think you are spending too much time and money on sharpening equipment. There are perhaps a half dozen sharpening systems in popular use (oil stones, scary sharp, diamond stones, waterstones, Tormek, etc); all are effective and if used correctly will bring up a used fine edged tool to razor keenness in a few minutes. I suggest hand tool users time yourselves. If when using one of the more popular techniques it takes longer than 3 minutes to sharpen a chisel or a plane iron from making chips to making chips your problem is personal technique not equipment.
