epoxy
epoxy
epoxy
alex
>Hi,
What type of epoxy glue do you recommend : G1 or T-88? These epoxy glue aren't too much expensive. Otherwise is there another epoxy glue that you would choose? That is for outside wood working.
Thank you.
Re: epoxy
Re: epoxy *LINK*
Gil Jones on Lake Seminole GA
>I use West System Epoxy. It is not cheap, but it has never failed me in use on woodworking and marine repairs or construction. I keep these on hand in my shop, plus lacquer thinner or DNA to thin it and clean up. Also, vinegar is good for getting epoxy off your skin>>
105A Resin (quart),
205B Fast Hardener 0.86 qt,
206B Slow Hardener 0.86 qt,
404 High-Density Filler - 15.2 OZ,
403 Microfiber Filler - 20 OZ.
I purchase these at West Marine in Tallahassee FL.
Gil
http://www.westmarine.com/webapp/wcs/stores/servlet/producte/10001/-1/10001/28496/0/0/epoxy/All_2/mode+matchallpartial/0/0
Re: epoxy
EDIT for the above post
>West System is a 5:1 mix, so you are well advised to buy the 5:1 dispensing pumps to fit the afore mentioned containers.
Gil
We really need to be able to edit our posts!!! This must be the only forum that does not have editing capability.
Re: epoxy
Raka is another alternative *LINK*
Craig Daymon
>Raka is a marine expoxy, like West Systems. (Seems the boating industry uses a lot of expoxy.) It's about half the price of West Systems. Last time I bought expoxy, it was West Systems, but next time I'm going with Raka. Sorry I can't give you a first hand account. They also offer pump dispensers for accurate mixing, like West Systems.
-Craig
Raka Marine Expoxy
Re: epoxy
Re: Raka is another alternative
Mark Rakestraw
>I've used Raka with good results on two kayaks. It has a thinner viscosity than some epoxies, making it easy to wet out fiberglass. If you're using it strictly as glue, you may want to add a little cabosil (I think that's the name of the thickener, ask when you order and they can set you up). Not strictly necessary, but if you have any gaps you want it to fill the thickener will keep it from running out.
Mark
Re: epoxy
I like System 3
Phileas
>I used System 3 when I built my sailboat. It's mix is 2:1, and you can buy pumps that fit the 1/2 or 1-gallon jugs. It was easy!
Try Jamestown Distributors
https://www.jamestowndistributors.com
or
Hamilton Marine
http://store.hamiltonmarine.com/browse.cfm
Cheers,
Phileas
Re: epoxy
Re: EDIT for the above post
Robert R Clough - Thorncraft
>Gil, you can edit your post. At the bottom of the writing page is a "preview message" and "post message". Just the first to check things over.
