Question: fixing polyurethane runs
Pat Evans
>Dad just put the first coat of poly on the desks we are building. There are a few minor runs. My very limited experience tells me trying to sand these out without affecting the color beneath is difficult. If I leave these and continue to apply subsequent coats, will they tend to disappear? If not, will sanding after several coats eliminate them?
Re: Question: fixing polyurethane runs
Bill Tindal, E.TN
>I have never had any success sanding runs. Scrape (with very sharp cabinet scraper) or plane them level.
Use a card scraper
Dave Bair, Eaton Rapids, MI
>After the coat of finish has fully hardened, a card scaper will quickly level the finish. If you don't have and cannot get a scraper, 220 sandpaper attached to a flat, hard backer can do an acceptable job of leveling runs. Again, wait for a fully cured finish or you'll end up with a crumbly, inconsistant finish.
If you've stained the wood and are worried about removing the tint, you can wait for more coats before addressing the flaws. If not,I wouldn't wait; the poly will look uniform once the raw wood is coated again.
Bartee (metro Atlanta)
>If it were me, I would let the 1st coat dry ( harden ) for a few days. Then using 220 or 320 and a sanding block very carefully flatten out the drips and runs without going too deep.
My poly method is 3 coats. 220 after the 1st coat. Red plastic "steel wool pad" after the 2nd and then white sanding pad after 3rd coat then wax ( this is like 0000 steel wool).
Maybe someone else has other ideas....
>Fully cured poly needs a sanding with 220 to create enough tooth for the next coat to adhere well. Partly cured (within 24 hours) poly will accept additional coats with out sanding. That's according to Minwax, anyway.
Al Killian
>I would use a scarp chisel to remove most of the run. Then continue applying the rest of the coats. It does not need to be perfect.
>I use a razor blade in the same manner you would use a card scraper to level the surface. Then sand lightly and continue with your finishing.
BilWil
>John Lucas is correct, I use the single edge razor blade approach as well. I is smaller than a card scraper, and my runs are usuall narrow, so I can control the razor blade more easily. Also, using the razor blade I don't have to wait for the poly to fully cure.
Razon Blade Gives A Better "RUN" For The Money
