OT? Truss Design
OT? Truss Design
OT? Truss Design
JohnM in Mid Mich
>So, I have a ton (figuratively speaking, not a unit of measure) of red and scotch pine currently dieing of some sort of insect attack. I'm thinking to harvest preemptively, and mill to dimensional lumber standards. Would like to use the resulting boards for new shed(s), barn(s), shop(s), or whatever. I'm more or less experienced with standard stick construction, but what about trusses? I've bought my share, but really, they look pretty simple to me! Is there some site/software/source of truss design assistance somewhere in this realm? I'm thinking that if I know I want (just for example) a 24 foot span, with a 1 foot gable, and with a 4:12 pitch, the truss design should be straightforward such that I could build them myself with a few pieces of Simpson (tm) metal and some fasteners. Got advice?
J.
Re: OT? Truss Design
Hal
>I have built them with plywood gussets before, you should be able to find some plans somewhere on line... good luck
Rob Hix - King George, VA
>Yeah, build them with plywood gussets and not only are they stronger, they will probably be cheaper. This is just going on what I am seing around here.
Rob
>Check out the Forest Products Laboratory and Universities like Virginia Tech. (VPI or VPISU) They will have truss desings particularly for farmers and agricultural use that you can build yourself.
Residential trusses (here) are "engineered" and are sold under the seal of a Professional Engineer. Your local Building Official may have something to say about using owner built trusses in a house, but probably woudl not object to using them in a shop or barns and sheds.
These designs will probably be based on plywood gussets and lots of nails. You might even glue the gussets. Important to lay them out nice and flat and nail them up.
Curly Smith
>I built a greenhouse a couple of years ago and did what you're suggesting. I started using plywood gussets but rapidly moved to the metal plates => they were a *lot* faster. Building a custom jig for your circular saw to cut the required angles is also a timesaver.
If you don't have them, there are good references here:
American Wood Council Span Tables
If you want to spend $100:
Easy Rafters (Cadd Software For Roof Rafter Design)
But, as the others have suggested, before you start building you should verify that your end product will meet the local building code.
