finishing to bring out the grain
Steve Silca
>I have a customer who bought a nice piece of sapele (tropical) from Owl Lumber in Des Plaines, IL for a countertop/shelf at her reception desk. She bought it because there was a display in the lumber store with a beautifully finished piece that really brough out the grain. Right now, I have the board and it looks fairly plain although I can see that there is potential for beauty if I can bring out some of the swirling figure of the grain. Has anyone worked with this wood or in general have good advice for really making the grain pop? It needs to be protective as well since it will be in a high traffic application.
Re: finishing to bring out the grain
>I did a small table of Sapele a while back. I was able to "pop" the grain using Waterlox original. YMMV
popping the grain
Michael Dresdner
>The best thing I have found for adding depth to wood figure is boiled linseed oil. Flood it on, unreduced, let it soak in for about ten minutes, then wipe off everything, leaving only what the wood has absorbed. Let it dry a couple of days, then add clear finish. If the finish you choose is oil or solvent based, it can go right atop the wood. If waterbased, I would add a tie coat of Zinsser SealCoat between the cured oil and the waterbased coating.
If boiled linseed oil adds too much color, the next best grain popper, and one that adds less color, is dewaxed shellac, which is what Zinsser SealCoat is. For that, flood it on as above, but wipe it off immediately. Let it dry two hours or more before continuing with any clear finish.
>The very best finish to reveal and highlight grain is water-white clear gloss lacquer. Oils just make mud.
Clint
Al Stokka - Cambridge, Iowa
>Since she likes what she saw at Owl Lumber, why not call Owl Lumber to find out what they used, then duplicate it.
Al
Second that!!
Pat Evans
>Photo is of unfinished oak plywood leaning against a desk made of the same piece of plywood but finished with boiled linseed oil. Tomorrow I start applying wipe-on poly. Photo was just taken under combination incandescent and fluorescent light without flash. It doesn't really do justice to the color of the oiled plywood, but you can get an idea of the difference.
