Dodge Dakota evaporator
Patrick Capobianco
>I have a 98 Dakota I was told that it would cost me around $900 to replace the evaporator. Has anyone tried to do this themselves? I heard it's a big job.
Patrick Capobianco
Re: Dodge Dakota evaporator
Jason Roehl in Mulberry, IN
>I don't know much about the Dakota in particular, but I'm pretty convinced that it's just not worth it to try to work on A/C systems if that is not your profession. If there is a leak, it will only get bigger. If a component is not working, how are you sure that is the component not working? And, even if you replace a few parts, there is a chance that debris from a broken part has migrated elsewhere in the system, possibly leading to its imminent demise. Then, even if you have replaced appropriate parts, the system needs to be evacuated (oh, yeah, the drier should be replaced, too, if the system is ever opened or leaked for a significant time) before it is recharged (also best left to the pros so that the correct amount of refrigerant is put in and the high/low pressures are correct, along with the correct amount of oil).
I say this as someone who, as much as possible, turns my own wrenches. If something isn't right on my vehicles, I generally try to tackle it on my own, but A/C doesn't fall under that purview anymore. I've learned a few expensive lessons along the way, but, by and large, I'm probably into the "saved money" area by not going to the shop every time something breaks. (I'm sure I've saved at least a couple thousand dollars over the past 10 years just by doing my own brakes).
I got my A/C fixed and converted to r134a last year for ~$375--a '93 F250. Now, after a long day painting in hot and humid weather, I can be mostly human by the time I get home.
Jason, who doesn't even notice the gravel in my driveway any more...been on my back in it too many times.
Tim Johnson
>I design car HVAC systems for a living. Depending on what type of system you have the evaporator is under the dash or in the engine compartment. If its under the dash this is major work because the whole IP needs to be pulled out. If its on the engine side it is much easier job.
I wouldn't recommend doing either job yourself. Unless you have the equipment and know what your doing to to suck out refrigerant and also suck down system so there is no moisture in it, its best to leave the work to a professional a/c mechanic.
Bill Howatt
>Don't know if this applicable to your problem but I has a '93 Blazer that had a small leak somewhere that couldn't be located. They put in some "stuff" that like the radiator Stop-Leak would seal small holes. Worked quite well for at least 3 yrs before we got rid of it.
I normally don't like to fix things in this manner but given the age of the vehicle, the cost and the fact it was a non-safety related item it worked out well in this case.
Bill
Woodenfish
>If you have some automotive mechanical skill this job really isn't all that bad. Usually on this vehicle the evaporator coil can be removed in a couple of hours by a novice or under an hour by a pro. There are not that many fastners that need to removed to take off the dash and extract the HVAC housing.
