O T lawnmower motor kickback
Paul Waddle
>What is the cause of kickback and jerking the recoil rope out of hand when trying to start mower? Is it a bent or broken connecting rod,bent crankshaft? It surely couldn't be as simple as the recoil clutch?I also had a chainsaw do this. Thanks,ouuch! this smarts! pow
Re: O T lawnmower motor kickback
Lee Schierer - McKean, PA
>Sometimes carbon build up in the combustion chamber can ignite fuel before the piston reaches top dead center and the motor will try to run the wrong way. Carbn build up problems are usually noticed on a hot motor.
A partially sheared key between the fly wheel and main crankshaft can also cause bad timing and premature ignition. Typically a partially shared key is cause by a lawn mower blade hitting an immovable object and instantly stalling the motor. I couldn't say what might cause that to happen on a chainsaw. I would check the points for wear or bad point gap setting as well.
Lee
Paul Waddle
>Thanks Lee,I'll check the key,if its ok,I'll pull the head and have a look at the piston and the head. pw
Joseph Mulherin Indio, CA
>In response, and agreeing with Lee, I would suggest running some alcohol along with the fuel for a couple tankfuls. Alcohol will clean out the carbon and the backfire should reduce or totally eliminate.
Or a mothball in the gas can.
s.mackay@worldnet.att.net
Phil Thien
>What kinda of alcohol and what ratio to gas? I have an old string trimmer that gives me grief sometimes.
TIA,
Phil
Fred
>Loose blade. The blade serves as a flywheel on some which have a light flywheel.
