Re: OT-Propane Plumbing
Larry Clinton At Frankfort (Central)., Indiana
>A few tips � but first my experience � I worked for a propane company for about a year (Hicksgas in Indiana) and installed HVAC and appliances for Sears for about 20 years (as a side job). You are correct in believing you can do the job yourself if you take a few precautions. First, where you are not passing through a wall, copper tubing, type L with flare fittings, is allowed � black pipe is also approved but it is more susceptible to leaks due to all the joints required. Make sure you check all your �flares� for cracks prior to assembly. Purchase Rectoseal pipe sealant (I believe I use # 3 � check the can for �approved for propane) and gas leak detection solution. The Rectoseal is far better at sealing pipe threads than Teflon tape. The gas leak detection solution is more accurate in finding small leaks than dish soap / water mix. Limit the number of gas shutoff valves to the minimum required. These are the culprit in 95% of the leaks found in installations. When I worked for the propane company, we were not allowed to use the corrugated flexible lines for the appliance hookup, although some are now listed as approved for this use. We used the Type L copper and coiled a length behind movable appliances like ranges. It is flexible enough to allow them to be pulled out for servicing without damage to the line. When you finish the job � be sure to apply leak detector to ALL fittings and completely around any gas shutoff's. Large leaks will show up as big bubbles immediately � go back and visually inspect all joints / valves about 10 minutes later as small leaks will cause �foam� around any bad joints.
