Veneering Problem
Veneering Problem
Veneering Problem
Howard
>I did a dry run on a pressing in a vacuum bag and the bottom platen curled upwards sufficiently to crack it.
Here is the setup: The bottom platen is a 4 by 8 sheet of melamine coated �� MDF. The part that I was pressing is about 2 by 6 feet with a �� thick Masonite top platen. The top platen overhangs about 3/8 inch. The pressure was about � an atmosphere as I was pressing honeycomb. The honeycomb was in rectangular frame. The material was not centered in the bag but about 12 inches off center.
After I started the pump I heard a cracking sound and on examining the setup I found that the bottom caul was bowed upwards with the bow greatest at one end of the bag and gradually decreasing to flat about 3 feet from the end. There was a 2 foot crack going down the center of the bottom caul.
A few days ago I made a smaller pressing, 2 by3 feet, using the same setup with no problem The work came out dead flat.
Lucky I had decided to do a dry run.
Any ideas as to the problem?
Re: Veneering Problem
DickL
>Does your bottom platen have grooves on its top surface to relieve pressure?
Howard
>Yes,
Some thoughts
Keith Newton
>When you started your draw-down, if the bag left the top platen with a long gentle sweep outward and down to the bottom platen, then the span between the two levels would create a bending force for the bottom one, and could cause this problem.
While you say 1/2 atmosphere, that could be 7 psi, and if you didn't push the bag into the corners as it was drawing down, it might sweep out maybe two inches, where the pressure of the excess bag provided traction against the bottom platen keeping it from sliding into the corner. A 2" span 72" long on each side is 288 square inches times 7 psi is 2016, you didn't give a thickness, which would factor into the bending force, which would be greater for the higher the angle of pull.
The lesson, is to avoid long overhangs on the top platen, and press the excess bag into the corners before the pressure is on.
Lee Grindinger
Huh?
Lee Grindinger
>I'm not able to understand what you're doing.
The platen is the grooved MCP, right? There's only one platen.
A caul is the piece that goes next to the veneer to even pressure, right? At most there are only two cauls.
So, how thick is the piece you're veneering? Are you veneering both sides at once?
How far above the platen is your stack of cauls and workpiece
As a rule if the piece I'm veneering is not oversize I veneer only the bottom side to avoid overhang with a caul, the pressure exerted by a vacuum will bend the top caul.
Lee
Re: Huh?
Howard
>Lee Here are the answers to your questions:
Ans: correct I mistakenly referred to the top caul as a platten
Ans: About � inch, Starting from the bottom up
Sheet of Formica
� inch thick wooden frame 2 by 6 feet, frame material is 2 inches wide, interior is filled with � thick honeycomb,
� inch Masonite caul
Ans. No
How far above the platen is your stack of cauls and work piece
Ans: only one caul sitting on top of work piece
Ans. That�s what I am doing
Lee
Thanks for your input,
Howard
Lee Grindinger
It sounds like the top caul
Lee Grindinger
>Try a dry run with no top caul or one that's the same size or smaller than the workpiece.
Lee
