Ok so I took the day off to clean the
Dustmaker Mike
>cars. I went to get some supplies and wouldn't you know it there was a Goodwill store right next door. I thought to myself why not see what kind of tables they have since the LOML and I are looking for a small dinning set.
Well it was our lucky day there was a table and 4 chairs (that matched) all a rustic pine look, just what the wife and I where looking for. The cost was $55.00 out the door with a solid wood no partical board set.
Now comes the trick on the top there is a 1/16th grove all around the edge of the table it is about a 1/16th deep just enough to collect yuck. I want to fill it is there a thin enough expoy I could use or do I have to widen it first then fill it?
Yes I did get a car done but the Heat beat me I surrender to the AC and a cool drink of water or two.
Re: Ok so I took the day off to clean the
In The Groove
>The size is not the problem, a steenth is ok, but the already accumulated yuck will likely present a problen with the epoxy bonding to the wood (won't stick to ick). I would carefully scrape out the groove with a sharp tool to both clean and deepen it into "fresh" wood fibers, then mix your resin. You can color your resin with compatible pigments or Transtint alcohol dyes work as well for colors. Others on the Board who work more with resin inlay can jump in here anytime.
mm
>Hello Mike,
Thats the best kind of table to get, especially one with a groove to catch all the spilled milk! Why not rout the groove deeper and inlay a different specie of wood in it?
George
Route a wider
Terry Quiram
>groove and inlay a contrasting color. Its a lot easier to do than you think.
Terry
