Ohio Forge contractor's saw update... *LINK*
>Mark kindly donated an old Grizzly tube fence and rails to the Licklog Players.
It turns out that the old Grizzly Fence and rails are a perfect replacement for the Ohio Forge table saw. The bolt holes for the rails matched perfectly. The fence would have fit on the old Ohio Forge rails, but the Grizzly rails had more capacity to the left of the blade, so I replaced the rails.
I ended up going through several 5" disks for my ROS (120-220 grit) and several sheets of 220 and 320 wet/dry sandpaper to clean up the top and wings. I left it to dry as I had quite a lot of WD-40 on it. I'll be waxing the top after the WD-40 evaporates. I donated a new 40 tooth carbide tipped blade to the "cause".
Licklog Players
