ADVERTISE HERE - FREE TRIAL
Pella wood window Finishing
Kevin Mac Luskie
>I've purchased and installed some Pella Architectural series windows, with the aluminium clad exteriors, and natural wood interiors. I opted not to have them finished at the factory (saving about $150 per window)
Having done that, I now need to finish them. My plan is to use several coats of glossy wipe on poly to make sure I get an even puddle free finish (I sometimes get a little overzealous with the thicker brush-on poly) But I wanted to see if anyone here had other suggestions or recommendations. Thanks for any advice.
-Kevin
Re: Pella wood window Finishing
Stew Pharis
>Kevin,
I've done a number of these windows. After staining them, I sealed with a coat of 1.5 pound shellac. I then used a quick dry oil varnish thinned 50% with mineral spirits and wiped on with paper towels. Any slop scrapes off easily and the finished windows look great.
Stew
Howard Acheson
>I would recommend you stay away from polyurethane varnish. Urethane rapidly deteriorates when exposed to UV from sunlight. It quickly discolors, cracks and crazes causing you to have to strip and recoat. Unless you get a true marine poly varnish, stay away from "exterior" or "spar" poly varnishes. They are very poor in performance.
I suggest you use a non-poly varnish like Waterlox Original Gloss or Satin.
If you want longevity and durability, use a paint.
judy fishman
>I have the same situation with Andersen wood windows, and with the interior wood trim around the windows. I want them to be unstained.
I have used Waterlox Semigloss on the floors which are longleaf and heartwood pine, and it worked well.
I would really appreciate suggestions on the best and easiest way to use the satin Waterlox on the windows and their trim, which are the same material as the floor Thanks.
Re: Satin Waterlox
Glenn Madsen near San Francisco
>is just about the easiest stuff to use for wood finishing.
For me, it works best to mask the pieces, throw down the drop cloth, and find a clean, old tshirt. Either wipe the Waterlox on full strength, or thin it by maybe a third with good mineral spirits, VMP naptha, or real turpentine. Let it cure a day or three, and come back and do it again. When it looks good, stop.
Get a white 3M pad, and rub it down, maybe with a little good furniture wax, until you get the satin gloss you need.
The tshirt should be hung up to dry, so that you don't get the spontaneous combustion problems not uncommon with varnishes and oils. Or burn it in the fireplace.
Re: Satin Waterlox
Steve Schoene
>One thing to add with the Satin Waterlox is that you need to stir it well (but not shake) before you start, and you need to stir frequently during the process. Satin finishes contain a "flatting agent" that can settle out if the varnish isn't stirred frequently, giving a streaky look of varying sheens.
If you are building a moderately thick finish, you will get slightly more clarity if you start with a gloss varnish, and only shift to the satin for the last coat or two.
Re: Satin Waterlox
John in New Mexico
>With most satin finishes I'd agree with you, but can't say as I've ever noticed solid content in Waterlox. Can't say how they make it satin, but the satin is much thinner and slightly darker in color to the gloss, with none of the satin sludge at the bottom. I think this is what makes it such an easy finish to use.
John
Howard Acheson
>Let me add to the suggestions that have already been made that you use some of the trim scrap to test the finish before you apply it to your windows. Put on the number of coats you will use on the windows. Waterlox adds quite a bit of amber to light colored woods and the Satin finish is more satin than many like. If it is too flat for your taste, you can mix it 50/50 with the Waterlox Original gloss. Initially buy only on container until you decide how you will use it.
Kevin Mac Luskie
>Thanks for all the suggestions and feedback on this! Sounds like a coat of shellac followed by several coats of Waterlox is the way to go. I'm currently planning on using the glossy, so shouldn't have to worry about the Satin finish issues.
One futher question. Would there be any additional benefit to using the Marine Waterlox? It appears to be only slighly more expensive. Would it provide more UV protection, or better water protection should say... the windows get left open in the rain, or someone puts a glass on a window sill and it sweats?
Thanks again for all the great feedback!
-Kevin
Wayne Stump
>Kevin,
You don't say where you're located, but if you are in a situation where the windows will sweat in the winter from condensation, I would recommend the following to prevent failure of the finish and possibly the wooden sash where the glass touches the wood at the bottom of the sash:
1. Steer clear of shellac-based finishes; they are easily susceptible to water damage. I did most of the windows in our home and the one failure that I had was where I used a pigmented shellac for the base/sealer coat.
2. Use a good masking tape and tape the entire glass to wood joint overlapping the tape about 1/8"(exact amount not critical) on to the wood surface.
3. Using a thin (I use a stiff 6" drywall knife) metal straight edge, rest the straight edge on the wood surface and cut the masking tape on the glass surface with a very sharp wallpaper knife or razor blade on the glass surface. This should leave a small area, the thickness of the straight edge, of the glass exposed just above the wood to glass joint.
4. Apply the finish, covering the exposed strip of glass as well as the wood sash--spar varnish is a good, or any clear coating with a high oil content (spar or marine type)
5. Remove masking tape after all coats of finish are applied.
The effect of this procedure is to leave a small area of durable finish sealing the joint between the glass and wood sash thusly preventing any condensation from penetrating the joint between the raw wood to glass surfaces.
FYI, I live in Minnesota and during our winters, we often get condensation running down the windows and this causes deterioration of the wood coating and eventually the wood, at the glass/wood joint. This procedure prevents that. This little trick also works with paint, preferably oil-based.
Good luck,
Wayne
Kevin Mac Luskie
>Thanks for the tips. The windows have a clear film pre-applied at the factory to protect them till the finishing is done. I'll see how easy/hard it is to use the drywall knife/razor blade technique to remove a small strip so there is a little bit of finish sealing agaist the glass.
I have to admit, I don't understand how the application of say a 1lb cut of shellac as a base/sealer coat underneath several coats of Waterlox would perpetuate early failure, compared to just the Waterlox.
I'm located in Southeastern Virginia, about 45 minutes from the coast. In the past we have had some condensation on our windows, although I attributed some of this to the poor quality of the windows (single pane, most don't have storm windows) The windows with storm windows were less prone to condensate. Also leaving the blind part way open to allow airflow reduced the condensation.
All the windows in the house are being replaced, along with all the siding on the exterior (so the house getting a well installed vapor barrier) and the interior walls are being stripped to the studs, and we are installing insullation (which there isn't any now) along with several other upgrades (ie wiring of all kinds)
