Sorta OT Relocateing a Washer and Dryer
Dustmaker Mike
>Ok by now you know I have a new place to call home almost we close the 21st of June). The washer and dryer are in the basement and I want them up stairs near the bedrooms. So here is my question.
I have a cloest next to the bathroom I can put them in but,the water is on the other side of the bathroom. So is there enough room behind a normal tub to run the water and drain lines for the washer? I will be putting in a shutoff and all other percautions but getting the water there and the drain is the challenge. Any other ways I even thought about riping up the floor and running it but that is a last resort.
Re: Sorta OT Relocateing a Washer and Dryer
Dan Manturi
>If I understand the layout, you are installing the washer on the wall OPPOSITE where the feed and drain is for the tub and want to know if you can put in a hookup and run the pipes between the back of the tub and the wall to reach the other side?
If so, you can likely hook the hot and cold by tapping into the tub lines and they should go around back easily. There should also be enough space for some 1 1/4" PVC for the drain. Hooking that up to the tub drain may be more of a challenge, but there should be enough space for the piping.
Problem with that is that the discharge rate of washers pushes a lot of water - hope it would not back up at all into the tub. It shouldn't if the tub drain is adquate.
Dan
Thanks and another question
Dustmaker Mike
>that is what I thought but was not sure. I can run the drain to the tub drain or a little bit farther to a basin drain. Which do you think would work better as long as both of them are a little down hill from the washer? Should I put a "P" trap inbetween?
Re: Thanks and another question
Nat Robison
>I would not run it to the tub drain if you have a choice for the earlier reason of output. You can put a trap where the washer discharges as long as its not heading into another trap at the basin. Double traps are not only redundant but not allowed by code (per my neighbor, the plumber). Don't know if there's a code requirement for the drain but my neighbor recently helped me plumb a a basement bathroom and laundry drain and he used 2" pipe. Also, wouldn't using smaller drain pipe increase the need for that pipe to be vented? My neighbor put a 1.5" vent alongside the 2" laundry standpipe.
Sizing....
>If you tapped into the bath's drain to put the washer's discharge, I wonder if you'd run into an overflow problem. If the bathtub was draining at the same time as the washer was pumping out, if the drain pipe could handle that much water at once the drain might backup and the washer would pump water onto the floor. Chances are you'd not have both draing at the same time, but if you did....
Happy Woodworking!
Re: Sizing....
Dan Manturi
>Yeah, that was my fear too. The pipe to my washer is about 1 1/4, but drains right down into 3" PVC. These washers really pump out the water, and it could back up into the tub. i would agree with another writer here that draining the tub and laundry at the same time would be interesting, depending on how far that tub drain is from the main 3 - 4" line.
Another thing to consider - you better not be taking a shower at the same time you are washing clothes, as when that washer is filling, the pressure is taken right away from the tub / shower. Just a time management issue, really.
Wow Thanks Again
Dustmaker Mike
>There is a pressure ball on the main line comeing into the house so I am not worried about water pressure. The washer is a front loader Maytag Neptune so it does not use much water to wash with. I will look at the drains when I get into the house to see what size they are. There are two bathrooms backed up to each other on the wet wall so I think I am in good shape as for sizeing. Thanks Again
Kneale Brownson in Northern MI
>What's below your closet?
All this taking from the supplies and adding to the loads for two bathrooms, if I understand you, could cause problems, especially with something as demanding as a washer. Your Neptune will discharge all of its watery contents quite rapidly. I'd look into ways to run new from the basement (where I presume your supply and wastes are located) and provide a new vent or vent connection for the washer drain.
Also consider whether you can add a slop sink in the "laundry room". That can be a very handy feature.
The Family Room is below it
Dustmaker Mike
>with no walls to run plumbing in. Thanks For All the input I see it is do able. Now I know what to look for before I open walls.
Re: The Family Room is below it
Dan Manturi
>Hey, is there room for a small laundry sink in the laundry area? You could have the washer discharge into the sink, and drain the sink into the tub drain. The laundry sink would act as a buffer, and water would just flow out at a normal, non pressured rate....
